New intake boots still leaking
- kz650guy
15 Feb 2018 16:13
Bought new intake boots for my 76 900 cleaned intake surface installed them checked for leaks with some carb or break cleaner around the boots still leaking I have used some rtv to seal leaks before just wanted to see if there is other options
Re: New intake boots still leaking
15 Feb 2018 17:01
Shouldn't have to use anything. Bolts too long?
- kz650guy
15 Feb 2018 17:20
I agree I used the oem screws that came out
- Z1Driver
- love the smell of triple smoke
20 Feb 2018 22:58
You didn't mention where the leaks were at. In the boots or at the mating surface with the head. There should be no leaks with new boots if installed correctly.
RTV doesn't work real well for plugging leaky boots. I found it was better to just replace the boots but in your case you already did. when I replaced my boots some years back I can't remember if I used fuel proof gasket sealer or not on the mating surfaces.
Hope you find the problem. Tim
Blue 1975 Z1B
Red 2009 Concours 14
- zed1015
21 Feb 2018 00:23
I use a smear of V-tech rtv ( the 600 degree stuff ) on both the intake flange and the face of the boot and leave overnight to cure once nipped up.
Peel away any excess from inside and outside the next day and you should be good to go.
- kz650guy
21 Feb 2018 21:07
Ended up using a very small amount of high temp silicone rtv worked just fine although I should not have had to use anything
21 Feb 2018 21:12
Were they brand new or NOS?
- kz650guy
21 Feb 2018 21:17
They were new from z1parts.com probably reproduction but they did say made in Japan
21 Feb 2018 21:20
They shouldn't leak.
