use both push and pull throttle cables?
  • 2strokerider
  • 2strokerider's Avatar Topic Author
30 Dec 2017 17:43
#776762
Can I get away with just using the pull cable on my 1979 KZ1000E?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: use both push and pull throttle cables?
30 Dec 2017 18:18
#776763
I use both.
  • RonKZ650
  • RonKZ650's Avatar
30 Dec 2017 19:15
#776765
I fought the push/pull cables and found the setup very difficult to make work correctly with low bars on a KZ1000 and KZ650. For some reason no matter how adjusted, I would get binding, and kind of an unwanted cruise control as the throtte would stick and not return to idle. On stock high bars I never had problem, and all my KZs now have stock bars and the setup works fine, but with low bars it stinks. What I'm trying to say I guess is no need for the double cables, but they don't hurt if working correctly. If not, get rid of the push cable.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
31 Dec 2017 05:03
#776774
Its very easy to adjust the cables. Adjust the pull cable with proper freeplay, then tighten push cable until it just starts to bind and back off a turn.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
31 Dec 2017 05:30 - 31 Dec 2017 05:32
#776775
Agree. I've owned my 1977 KZ650-C1 for nearly 41 years and never had a problem adjusting the 2 throttle cables. I use genuine Kawasaki cables, but I don't think that would make a difference. I guess if they were not routed properly they might bind. Ed
Last edit: 31 Dec 2017 05:32 by 650ed.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
31 Dec 2017 06:19
#776776
Hi 2strokerider,
A closing cable can be used as a convenient opening cable in a pinch, at least on Z-1's. The KZ-1000 carb cranks are similar.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
