CR29 jetting and decel backfire
  • BOOM_FIST
  • BOOM_FIST's Avatar Topic Author
02 Oct 2017 06:14
#772175
So, I felt like I have been messing with these darn carbs since I bought the bike a year ago.
After taking OMR's advice on jetting, since we have similar set-ups, the bike is running a lot better than when I first got it, but still need fine tuning.
I feel the jetting is spot on, but I'm still getting some backfire on decel. Not too horrible, but more than I want. My air screws are only turned 1/2 turn out! I don't have much more to turn in. Does that mean bigger pilot jet needed? Or turn another 1/8th or 1/4 in?? Anyone else with this set-up that can chime in??
Either way, I'm about to drop the $250 for the Yoshi MJN drop in tube kit to see if that helps any with these touchy carbs!
Any help is appreciated!
1977 KZ900A5
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: CR29 jetting and decel backfire
02 Oct 2017 06:36
#772176
Are they synced? Valves adjusted?
  • BOOM_FIST
02 Oct 2017 10:18
#772182
Yes and Yes.
Was reading up...I could try raising the needle (or lowering the clip, whichever) one notch as well to adjust for the lean condition???
1977 KZ900A5
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Oct 2017 13:01
#772187
Yes in the midrange.
  • BOOM_FIST
02 Oct 2017 15:47
#772204
Right, ok...
Just rode home from work and it was almost 20 degrees warmer than this morning and it rode worse.
So all the symptoms lead to, step up in pilot jet size, but what am I missing here? OMR is running a very similar setup and this is what he's running with it even being more on the rich side....I'm losing my patience with jetting these flippin carbs.
1977 KZ900A5
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Oct 2017 16:54
#772208
Go one full step up. Example 20 to 30. Not 20 to 25. Don't adjust anything until the pilots are right.
  • BOOM_FIST
02 Oct 2017 17:29
#772212
I'll try that, but I was running 52 pilots and 112 mains all summer and never had this bad of lean pop and backfire until I switched to 55 pilots. Doesn't make sense.
I'll put the 65 pilots back in and try from there. I mean, all the symptoms lead to try that anyway sooo...
Thanks SWest
1977 KZ900A5
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Oct 2017 18:22
#772217
Pic of the plugs?
  • Dr. Gamma
  • Dr. Gamma's Avatar
02 Oct 2017 19:13
#772222
BOOM_FIST wrote: I'll try that, but I was running 52 pilots and 112 mains all summer and never had this bad of lean pop and backfire until I switched to 55 pilots. Doesn't make sense.
Thanks SWest
Why would you go up 5 SIZES ON PILOT JETS???? One size makes a BIG differeance.
Keihin CR pilot jets go 50,52,55,58,60,62,65,68.
I have had CR's on my bikes since back in 1981, and I have NEVER had to go up 5 sizes at any time.
I got 65 pilot jets in my 33CR's on my 1105cc motor!!!
1986 RG500G 2 stroke terror.
  • BOOM_FIST
03 Oct 2017 02:30
#772235
SWest wrote: Go one full step up. Example 20 to 30. Not 20 to 25. Don't adjust anything until the pilots are right.
Dr. Gamma wrote: Why would you go up 5 SIZES ON PILOT JETS????
Well, because another member suggested it this way....plus I have 65's in my possession and I just ordered 2 sets of jets just last week to include the 55's that don't seem to be working and I really didn't want to order more jets again.
Are you suggesting that I go with 58's or 60's instead?
I rode in again this morning after a plug cleaning and it ran just about the same. I'll pull the plugs when I get home and report back.
1977 KZ900A5
03 Oct 2017 06:44
#772248
One remote but conceivable possibility is that the previously installed non-popping pilot jets had been "drilled out."
Good Fortune! :)
  • BOOM_FIST
04 Oct 2017 04:20 - 04 Oct 2017 04:21
#772307
Patton wrote: One remote but conceivable possibility is that the previously installed non-popping pilot jets had been "drilled out."
Good Fortune! :)
Well I'd hope not as I bought them new from JetsRus!
Please bear with me as I'm still a NEWB to these bikes and carbs! I don't think I mentioned that the pops are coming out of the exhaust, not the carbs. After researching and trying to find what my exact problem is, it seems that I haven't been setting the air idle screws correctly. I thought the symptoms of the popping exhaust were because I was running lean, when in fact I'm running rich? Am I correct in saying that?
Rode home from work and could tell the plugs were fouling up by the way it sounded and felt. I pulled them last night and 1 and 2 seemed good, but 3 and 4 had some black on them. 4 more than 3, but neither completely sooted up. And I kept smelling the rich mixture every time I came up to a red light/stop sign. Duh...should have known just by that alone that I was running rich.
But every time I back the air screws out to try and lean 3 and 4 out, it starts to run like crap. I'm also getting a little surging in the low end while cruising...very similar to when I first bought the bike and had the 65 pilots in. Slow cruising speed was very choppy. Again, symptoms of running rich, not lean.
With all of this, it seems I'm running rich still and I'm wondering if I need to swap back in the 52 pilots and reset the air screws and tune again? Anyone agree?
Thanks again for all of the input you guys, it's much appreciated!
1977 KZ900A5
Last edit: 04 Oct 2017 04:21 by BOOM_FIST.
