Honda xr600 twin carb setup on kz750 ?
- SuzukiTC125
30 Aug 2017 21:56
I have a hunch that it wouldn't be too hard to rejet the xr600 honda twin carbs for my kz750 build that I want to take on in the next couple of months. What does the form genius's think about the idea? I will make my own air intake boots custom fit.
Currently have equal and good compression,
Currently have open exhaust. (PO cut them off)
Currently will be running uni pods or KN pods.
Before I go flying to the wind with jet combos I wanted to ask around first.
I know it is against the law on forms of not doing research before posting but does the group have any thoughts on niche cycles kz750 prejetted carbs vm34s on eBay ?
- baldy110
Re: Honda xr600 twin carb setup on kz750 ?
06 Sep 2017 19:07 - 06 Sep 2017 19:11
Won't work the carbs are not the same. They are completely different, the left carb has an idle curcuit the right one does not so your left cylinder will be the only one able to idle. And the right one cannot be modified to work at idle.
Last edit: 06 Sep 2017 19:11 by baldy110.
06 Sep 2017 20:25
No eBay APP ID and/or Cert ID defined in Kunena configurationMight make an offer on these.
