1978 kz750b carb floats
- wolfgang4999
03 Aug 2017 06:40
i have bought 2 sets of floats for my 1978 kz750b carbs and none of them work right. they hang up in the bowl and seem to not shut off the fuel when full of gas. anyone have any suggestions??
Re: 1978 kz750b carb floats
03 Aug 2017 07:15
Are the floats the plastic or brass once?
Brass floats can have micro holes that fill them with fuel and let them sunk to the boal ground.
The following user(s) said Thank You: GPz550D1, wolfgang4999
- wolfgang4999
03 Aug 2017 09:50
brass. they float. i checked them before putting them in. when i go to put the bowl on it looks like they are pushing up as i push the bowl on and i fill the lines going into the carb with gas and it just keeps taking gas like they are not shutting off. i rebuilt the whole carbs and everything is new.
- JWKZ750
04 Aug 2017 05:33
Yes i had the same probably on my 77 Twin until I got these.
wolfgang4999 wrote: brass. they float. i checked them before putting them in. when i go to put the bowl on it looks like they are pushing up as i push the bowl on and i fill the lines going into the carb with gas and it just keeps taking gas like they are not shutting off. i rebuilt the whole carbs and everything is new.
04 Aug 2017 07:19
If the tang is too much on an angle they will cock the needle sideways and preven seal. They are for fine adjustments only.
04 Aug 2017 07:51wolfgang4999 wrote: i have bought 2 sets of floats for my 1978 kz750b carbs and none of them work right. they hang up in the bowl and seem to not shut off the fuel when full of gas. anyone have any suggestions??
Bought new or used?
