Engine backfiring upon start up
- Kawasakikz650
26 Jul 2017 12:52
i have owned a 1980 kawasaki kz650 for about 5 years now and has always run great i had rust in the gas tank and had to get a new tank and clean all the carbs really good... now that i have done that the exhaust backfires upon startup and gets worse as i crank the throttle... also small flames popping out the back any ideas on what could be wrong with the bike i would hate to get rid of it since it is such a great bike
Re: Engine backfiring upon start up
26 Jul 2017 19:29
Clean the pilots again.
27 Jul 2017 07:41 - 27 Jul 2017 07:48
Insufficient intake valve clearance can cause backfiring through the carb. As can any other reason behind why the supposedly closed valve isn't fully seating, such as burnt valve or seat, bent valve, needing a valve job, etc.
Popping through the exhaust on deceleration can sometimes be remedied by slightly enriching the pilot mixture(s).
If not already done, would also assure proper functioning of the ignition timing advancer (most easily done with a timing light). It's sometimes necessary to clean and lube the advancer.
Hope the advancer doesn't look like this:
Last edit: 27 Jul 2017 07:48 by Patton.
27 Jul 2017 08:28
Spark plug wires swapped?
- KZB2 650
27 Jul 2017 10:16 - 27 Jul 2017 10:18
Lot of these problems popping up lately (including me)..... all of the above and be sure you have a good inline filter..... carbs can look clean enough to eat off of and pilots can still use another cleaning with high pressure air, cleaner, wire and sometimes a soak depending on how bad they were at the start....... could be leaking air boots too (new boots for me) .....thinking it was in my case hitting the pilots one more time and buying a better gas filter.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 27 Jul 2017 10:18 by KZB2 650.
