Looking to fine tune factory KZ1100 carbs
  • 76KZ900
  • 76KZ900's Avatar Topic Author
19 Jul 2017 14:02 - 19 Jul 2017 14:03
#767316
I did some searching and found a post a while back from wired george that said with my pipe and pod filters to use 140 mains and 40 pilots. i used the 40 pilots but only had 135 mains (factory ZRX jets) bike runs way better from roll on but I've noticed what I believe to be more popping on decel than prior to jetting. To me this dont really make sense since popping on decel is normally from lean condition. But since Ive enriched both circuits I don't get it. I did not mess with metering screws yet. Im guessing they are going to need opened a bit ? Anyone ? The 140 jets have been ordered.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
Last edit: 19 Jul 2017 14:03 by 76KZ900.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Looking to fine tune factory KZ1100 carbs
19 Jul 2017 17:04
#767331
Adjust the pilots then see if it goes away. Have you synced the carbs?
  • Nebr_Rex
  • Nebr_Rex's Avatar
19 Jul 2017 18:35
#767343
5 or 6 [?] years ago somebody on the forum found a different jet needle that
worked great for the BS34s. You might want to checking the archive.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • 76KZ900
19 Jul 2017 23:43
#767359
I have not syncd carbs after valve adjustment. I will after I put the 140 mIns in. I seem to remember with my ZRX I had to raise jet needle with a brass washer to help eliminate the popping.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
