1978 KZ650C2 petcock woes
  • 2wheeljake
  • 2wheeljake's Avatar Topic Author
Re: 1978 KZ650C2 petcock woes
09 Jul 2017 19:24 - 09 Jul 2017 19:30
#766530
Yes - I measured 45 mm (I'm a Canuck!) which is about 1.749 in you measured - now to find one!
Thanks Again!
Last edit: 09 Jul 2017 19:30 by 2wheeljake.
  • 2wheeljake
09 Jul 2017 19:29
#766531
Good to know - I'm looking for a manual one ideally...my float needle seats are sticking even after cleaning them thoroughly (this bike has been sitting many years - I just picked it up) even finding carb rebuild kits is proving tricky...just sorting out what I can find to work with...after cleaning stock carbs fuel is still puking out - as I can't turn the leaky vacuum petcock off - it flows in every position...
Jake
  • davido
  • davido's Avatar
27 Jul 2017 04:31
#767800
I finally got around to stripping my tap off again for another clean up. I looked at finding a non vacuum replacement but my local shop suggested that it might be cheaper to just fit a regular on/off tap further down the line. A good idea,in theory, but I dont have enough room twixt tank and engine to get my fingers on it. Maybe it could work on the 650. Certainly cheaper and less work than other options.
On a side note,the link I posted earlier about the tap rebuild tutorial has now been photofucketed !
xjbikes.com/forums/threads/rebuilding-th...-valve-w-pics.25058/
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
