Rich running problem
  • Lnovak7493
  • Lnovak7493's Avatar Topic Author
Re: Rich running problem
12 Jun 2017 17:51
#764182
Damn. yeah i need to do that. Where do you hook the timing light up when you time it?
1981 kawasaki kz1000-k1 ltd
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2017 17:57
#764183
To the battery +, a bolt on the frame and around a spark plug wire.
  • Lnovak7493
12 Jun 2017 18:04
#764186
Thanks man
13 Jun 2017 04:14
#764212
Some models come from the factory with fixed timing that's not owner adjustable. In which case the timing and operation of the advancer may be viewed with a timing light to confirm correctness of timing and proper functioning of the advancer, but without being owner adjustable.
With an ignition that's owner adjustable, such as a points ignition or a Dyna-S electronic ignition, the ignition backing plate would be expected to have slotted holes to allow for adjustment of timing by the owner.
The ignition pictured by SWest is, i believe, a Dyna-S electronic ignition (which perhaps replaced an original points ignition) and has a slotted backing plate which allows owner adjustment.
The ignition at hand might or might not allow for owner adjustment of the timing.
What ignition is the ignition at hand? Points? Dyna-S? Stock igniter style?
Good Fortune! :)
  • Lnovak7493
15 Jun 2017 19:24
#764478
Stock non adjustable pick up. Im about to order the ddk2-1c kit
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
26 Jun 2017 05:52 - 26 Jun 2017 06:27
#765405
SWest wrote: When I reset the valves everything changed.
At 1:42 you mention "tightening the springs on the spark advance...walking back and forth."
The Dyna 2000 ignition system replaced the factory spring/weight mechanical advance on my engine. Same with yours?
That "walking back and forth" is likely happening because the adjustable pickups (on the adj. plate) are slightly out of sync to one another. Shouldn't the timing between 1/4 and 2/3 be dead-on identical? :whistle:
1982 KZ1100-A2
Last edit: 26 Jun 2017 06:27 by daveo.
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Jun 2017 06:39
#765407
If the springs have slop in them, the timing will walk back and forth.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
26 Jun 2017 11:23
#765425
SWest wrote: If the springs have slop in them, the timing will walk back and forth.
Your Dyna ignition has springs?
1982 KZ1100-A2
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Jun 2017 11:54
#765426
Dyna S uses the spark advance.
  • Lnovak7493
02 Jul 2017 07:56
#765890
Is it possible to do piston rings with the engine in the frame? Also can i just like move the head to the side while i do the rings so i dont have to split the cases?
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jul 2017 07:59
#765892
Do you have a manual?
  • KZB2 650
  • KZB2 650's Avatar
02 Jul 2017 08:02
#765895
You can do rings without splitting the case ..... I did my pistons without but I did remove the motor and rigged it up on a stand so I could remove the oil pan and flush every thing out real good.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
