Removal of Emission Control on KZ1000 Police
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Removal of Emission Control on KZ1000 Police
20 May 2017 19:10
#762344
I don't think that's a overflow. Maybe a vent with a check valve.
The following user(s) said Thank You: bl_francis
  • bl_francis
  • bl_francis's Avatar Topic Author
20 May 2017 19:15
#762345
SWest wrote: I don't think that's a overflow. Maybe a vent with a check valve.
Should I be able to push or pull air through it when the petcock isn't hooked up and the bike isn't running?
1987 KZ1000 Police
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 May 2017 19:32
#762347
They got really anel about anything escaping into the atmosphere.
  • bl_francis
20 May 2017 19:37
#762348
SWest wrote: They got really anel about anything escaping into the atmosphere.
Yeah, my plan was to try to keep it all original but I thought that switch valve might be toast so I checked out the thread where someone else had taken all of that stuff off. I was wondering If I had done it correctly.
1987 KZ1000 Police
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 May 2017 19:56
#762349
Looks good to me. I used plastic plugs from the HDWR store for my airbox.
  • bl_francis
20 May 2017 20:05
#762351
Great! Thanks for your help!
1987 KZ1000 Police
  • TexasKZ
  • TexasKZ's Avatar
20 May 2017 20:25 - 20 May 2017 20:26
#762352
If you are asking about the hose that comes from the sending unit cover, that is just in case the sending unit or its gasket begin to leak.
Last edit: 20 May 2017 20:26 by TexasKZ.
The following user(s) said Thank You: loudhvx, bl_francis
  • martin_csr
  • martin_csr's Avatar
21 May 2017 04:58
#762362
By TexasKZ: If you are asking about the hose that comes from the sending unit cover, that is just in case the sending unit or its gasket begin to leak.
..... so that fuel won't leak onto a hot engine. In case it needed to be said. hee.
  • bl_francis
21 May 2017 07:50
#762372
So there's a valve in there that opens up with pressure on it? Should I be able to push air through it?
1987 KZ1000 Police
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 May 2017 07:54
#762373
I think Martin is right about it being a catch basin. I wouldn't be concerned with it.
  • bl_francis
21 May 2017 07:56
#762374
SWest wrote: I think Martin is right about it being a catch basin. I wouldn't be concerned with it.
OK. Thanks a lot.
1987 KZ1000 Police
  • bl_francis
21 May 2017 21:11
#762440
I put everything back together after doing the valve adjustment. It ran for a few minutes but a lot of smoke was coming off of the engine, I couldn't see what was causing it. Could it have something to do with adjusting the valves?
1987 KZ1000 Police
