- Thank you received: 13
Frozen float bowl drain screw ?
- kzdcw
- 77' KZ1000A
29 Apr 2017 16:24 #760659
by kzdcw
77' KZ1000A
Frozen float bowl drain screw ? was created by kzdcw
As I'm cleaning and rebuilding Mikuni 28mm accelerator carbs., my #2 float bowl drain screw won't screw out or loosen ? These are used carbs. I'm rebuilding and the float bowl drain screw slot is a little buggered up but still able to get a large thick blade screwdriver between the screw head slot and hold well.
I've soaked both sides of the screw with Kroil oil for at least a day or so. Even tried running my Heat Gun over the outside of the float bowl body around the screw for a couple of minutes but still not budging ? Tried tapping the top of the drain screw with a hammer, still no luck ?
Any ideas on how to remove it or just leave it alone ?
77' KZ1000A
- kzdcw
- 77' KZ1000A
- Thank you received: 2072
30 Apr 2017 04:22 #760690
by Scirocco
Replied by Scirocco on topic Frozen float bowl drain screw ?
Please take some pictures to get a better view of your problem
- kzdcw
- 77' KZ1000A
30 Apr 2017 04:41 - 30 Apr 2017 04:43 #760692
by kzdcw
77' KZ1000A
Replied by kzdcw on topic Frozen float bowl drain screw ?
Sorry, I don't have anything to take a picture with. It's just that the big slotted drain screw on the bottom side of the float bowl doesn't loosen ?
77' KZ1000A
Last edit: 30 Apr 2017 04:43 by kzdcw.
- Thank you received: 2829
30 Apr 2017 04:52 #760695
by 650ed
Replied by 650ed on topic Frozen float bowl drain screw ?
If you are referring to the screw shown below be sure to use a screwdriver with a large blade that fits the screw. That should give sufficient bite to loosen it. Ed
30 Apr 2017 04:55 - 30 Apr 2017 05:01 #760696
by Scirocco
Leave it as it is. If you use more force on it you will crack the bowel or snap off the screw head.
Rust or oxidation lock the threat very strong
Try to find a replacement on eBay.
Last edit: 30 Apr 2017 05:01 by Scirocco.
- kzdcw
- 77' KZ1000A
30 Apr 2017 04:59 #760699
by kzdcw
77' KZ1000A
Ed, That is the screw that I'm talking about . And I'm using a Large Blade screwdriver that fits the slot well ? Unfortunately, nothing is working yet and I didn't want to use an impact driver in fear of breaking something. I really wanted to remove them and even replace with new and o-ring. but maybe I should leave well enough alone ? Then it would prevent me from setting the float levels with the clear tube method.
77' KZ1000A
- Thank you received: 2839
30 Apr 2017 05:03 #760700
by Nessism
Replied by Nessism on topic Frozen float bowl drain screw ?
You could try a torch to heat it. Heat the screw, not the float bowl, and get it HOT.
I had a drain screw on a CV34 Keihin recently that wouldn't come out. I wound up buggering up the the head of the screw big time but eventually got it out. Huge pain in the butt. Hope yours isn't as stubborn.
30 Apr 2017 05:07 #760702
by Scirocco
Maybe an idea, try to boil it for an half hour in water with citric acid and try it again
- slmjim+Z1BEBE
- Thank you received: 740
30 Apr 2017 07:49 #760735
by slmjim+Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Replied by slmjim+Z1BEBE on topic Frozen float bowl drain screw ?
Hi kzdcw,
Been thinking about this. Apply too much torque to a slotted brass screw and half the head might break off at the slot.
If you're willing to sacrifice the screw, try to get a toothed tool to grab the edges of the screw head, something like the curved inner jaws of slip joint pliers. It should only require a few degrees of rotation to turn free. Hopefully a PO didn't apply thread locker for some reason. As previously mentioned, heat gun. And gloves. Good luck.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- bluej58
- Thank you received: 511
30 Apr 2017 08:17 - 30 Apr 2017 08:20 #760739
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic Frozen float bowl drain screw ?
Like Nessism say's use heat, but when I do it I heat the bowl to expanded it and soften the lacquer on the threads.
hot air or boiling will work, boiling may be better.
patents, it will come loose, use the biggest flat blade screwdriver that fits and clamp it down or hold it in a towel or a heavy leather glove
78 KZ1000 A2A
Last edit: 30 Apr 2017 08:20 by bluej58.
- kzdcw
- 77' KZ1000A
30 Apr 2017 15:45 #760793
by kzdcw
77' KZ1000A
Do you heat the head of the drain screw or heat the area of the float bowl around it ?
77' KZ1000A
