Frozen float bowl drain screw ?
Re: Frozen float bowl drain screw ?
30 Apr 2017 15:52
Heat the screw. The idea behind it is to break the corrosion bond, not expand the metal.
- kzdcw
- 77' KZ1000A
30 Apr 2017 16:56 - 30 Apr 2017 17:12
Nessism, It worked !!! The mistake I was making was also trying to use a large blade screwdriver instead of a good set of channel locks. Carefully grabbed the outer edge of the head of the screw, squeezed the plier handles hard, and carefully turned screw out. Worked like a charm. Now to continue on with the rebuild. Thank You to "All" that responded to my post.
77' KZ1000A
Last edit: 30 Apr 2017 17:12 by kzdcw.
