- Thank you received: 13
Pingle dual outlet to single inlet carbs. ?
- kzdcw
- 77' KZ1000A
20 Apr 2017 14:02 #759685
by kzdcw
77' KZ1000A
Pingle dual outlet to single inlet carbs. ? was created by kzdcw
I'm probably asking the obvious, but my 77' KZ1000A gas tank has a new Pingle dual outlet fuel petcock. The ( 2 ) fuel lines leaving go to the stock carb. ( 2 ) fuel Tee's . The used set of carbs. I have and am planning to mount down the road are 28mm accelerator pumpers. They only have a single ( 1 ) fuel inlet on the carbs.
So my question is, do I run 2 fuel lines from the petcock to a Y-splitter, then a single ( 1 ) fuel line to the fuel T on the carbs. ? Hate to loose my New Pingle fuel petcock.
77' KZ1000A
- kzdcw
- 77' KZ1000A
23 Apr 2017 19:12 #760076
by kzdcw
77' KZ1000A
Replied by kzdcw on topic Pingle dual outlet to single inlet carbs. ?
Anybody, Anybody ???
77' KZ1000A
- Thank you received: 2755
23 Apr 2017 21:15 #760093
by SWest
Replied by SWest on topic Pingle dual outlet to single inlet carbs. ?
Use the splitter. Is the line to the carbs larger?
- kzdcw
- 77' KZ1000A
24 Apr 2017 04:01 #760096
by kzdcw
77' KZ1000A
Steve, The fuel line that I'm using will slide over the fuel T at the carbs. and splitter tightly . Will use some fuel line clamps if needed . I was just trying to avoid purchasing another fuel petcock .
77' KZ1000A
- Thank you received: 2237
24 Apr 2017 04:38 - 24 Apr 2017 04:39 #760098
by TexasKZ
Replied by TexasKZ on topic Pingle dual outlet to single inlet carbs. ?
I say do it. If you can come up with a fuel resistant cap for one of the barbs on the fuel valve, you would have a more elegant solution. You would want to be sure that the single line is the same inside diameter, or larger, than stock to insure sufficient flow.
Last edit: 24 Apr 2017 04:39 by TexasKZ.
The following user(s) said Thank You: GPz550D1, Patton
- jdvorchak
- Thank you received: 50
24 Apr 2017 05:29 #760103
by jdvorchak
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Replied by jdvorchak on topic Pingle dual outlet to single inlet carbs. ?
The only experience I have with a dual outlet petcock is on my 71 CL350. interesting to note that it will only flow fuel out of one hole at a time if only one line is drawing fuel. Plug that line and fuel comes out the other outlet. I found that out when I was trying to drain my tank for removal. I hope that makes sense? So I vote for the "Plug one outlet and use a single line to the carbs keeping the Pingle".
John
83 KZ550M1
83 KZ1100LTD
Also own:
