How do I know if I need a carburetor sync?
- skilledman101
18 Apr 2017 06:55 #759496
by skilledman101
How do I know if I need a carburetor sync? was created by skilledman101
I got an 83 KZ750 this past week that hadn't run in a few months. Cleaned out the 4 carbs and after some starter fluid and playing with the choke, I got the bike to run and rev consistently, however if the RPMs dropped to below 3000, it would just die. When the bike was above 3000 RPMs, the left two cylinders would run great, however the right two appeared to only be getting gas sometimes and were spotty when running (you could hear it and see it). Is this a carb issue? I was told the carbs needed to be synced.
- Thank you received: 2839
18 Apr 2017 07:03 #759498
by Nessism
Replied by Nessism on topic How do I know if I need a carburetor sync?
It's not a sync issue. Your carbs are dirty.
- skilledman101
18 Apr 2017 07:12 #759500
by skilledman101
Replied by skilledman101 on topic How do I know if I need a carburetor sync?
I cleaned those carbs thoroughly. It can't be that. Bowls, needle, jets, all the brass parts, diaphragm. etc. were all gone through and cleaned out.
18 Apr 2017 07:26 - 18 Apr 2017 07:28 #759501
by Nessism
Did you remove the pilot jets and main nozzles to make sure the orifices are open? Did you remove the pilot screws to make sure all the passages are open? How far open are the pilot screws?
Also realize that the airbox and air filter needs to be installed or the bike won't run well if at all.
Last edit: 18 Apr 2017 07:28 by Nessism.
- Thank you received: 2755
18 Apr 2017 07:27 - 18 Apr 2017 07:52 #759502
by SWest
Replied by SWest on topic How do I know if I need a carburetor sync?
The pilots are very small. You have to make sure they're clean with a guitar string or wire brush strand. A sync is the last step after all else has been done like valve adjustments. If you take out the carbs they must be synced again.
Last edit: 18 Apr 2017 07:52 by SWest.
- Tyrell Corp
- Thank you received: 261
18 Apr 2017 15:08 #759537
by Tyrell Corp
Replied by Tyrell Corp on topic How do I know if I need a carburetor sync?
Maybe do a rough 'bench synch' first then balance them using vac gauges, to avoid any possible gross maladjustment masking any other problems..
You know when it is right as you get that 'whoom whoom' sound back when blipping the throttle.
The idle circuit(s) always block first, as the orifices are so small.
- loudhvx
- Thank you received: 1616
18 Apr 2017 15:11 #759538
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic How do I know if I need a carburetor sync?
Make sure you didn't miss some hidden jets. Sometimes there are jets on top of other jets, and sometimes there is a jet hidden under a plug.
1981 KZ550 D1 gpz.
Other links.
