hanging idle, no leaks...
- spdygon
Re: hanging idle, no leaks...
03 Apr 2017 08:06
Sorry did not read all the post but using a finger push each slide one at the time all the way up and should return down smoothly.
If one hangs or sticks no good
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- shamal
03 Apr 2017 08:51Ok, thank you. But if you try to finger stop your vscuum piston while the engine its running, you will discover that those have nothing to do with idle dropspdygon wrote: Sorry did not read all the post but using a finger push each slide one at the time all the way up and should return down smoothly.
1983 kz 550 h
- shamal
05 Apr 2017 09:04
I dont know if due of adjusted air gap in the pulser coils or the fourth bench sync, but after the new cdibox the problem is sorted. I will keep you on..
i have to drive
1983 kz 550 h
