hanging idle, no leaks...
The following user(s) said Thank You: GPz550D1, mopguy, shamal
Re: hanging idle, no leaks...
24 Mar 2017 08:33
If you haven't already done so, try this -
Disconnect the throttle cables at the carbs. The start the bike and give it some revs by manipulating the throttle at the carbs using your hand. If the revs still hang you have ruled out the cables and throttle grip as a possible problem. If the revs still hang you have identified the problem which should be easy to correct by lubing the cables and throttle grip. Ed
The following user(s) said Thank You: GPz550D1, shamal
- shamal
24 Mar 2017 08:43
Cable its ok and snap return as it should..
1983 kz 550 h
- shamal
24 Mar 2017 11:50
Can be a sticky valve problem?
1983 kz 550 h
24 Mar 2017 12:24shamal wrote: Can be a sticky valve problem?
Doubt it. Pretty sure it's a lean mixture or maybe spark at wrong time.
The following user(s) said Thank You: shamal
- shamal
24 Mar 2017 14:19
I have a GPX 750 cdi for spare. Can i use it?
I know the pinout its the same. I don't know
If will work.
Toughts?
If will work.
Toughts?
1983 kz 550 h
- shamal
25 Mar 2017 03:06
Update.. right now i checked with the timing light idle ignition timing. Its perfect matched "F" with the crankcase mark.
I thighten more the boots , i dont want to bent them so i dont know if is good thightening too much.
Idle is still as above.. it drop to normal but just take a pair of second ..
1983 kz 550 h
25 Mar 2017 06:14 - 25 Mar 2017 06:16shamal wrote: ...new carb diaphragm....
Perhaps one of the vacuum valve throttle slides might be ever-so-slightly hanging, for whatever reason, such as imperfect fitment of the replaced diaphragm or a speck of crud in one or more of the carbs that's interfering with immediate full down position seating/closure of the throttle slide upon closure of the throttle.
Am presupposing that all the vacuum valve springs and spring seats and jet needles and needle jets are all in perfect condition and are properly installed in what are believed to be immaculately clean carbs.
Last edit: 25 Mar 2017 06:16 by Patton.
- shamal
25 Mar 2017 07:28
The carbs are clean. Trust me. Ultrasonic.
Jets the same.
I was thinking about that too, but when i close the gas, the butterflies are closed, so i think even if a slide valve can be slower than others when close , have this influence? I think not so much
Jets the same.
1983 kz 550 h
26 Mar 2017 01:09
FSM If needed:
Click here > www.dropbox.com/s/8g47k3pmjmoxc97/GPZ900R%20FSM%201990.pdf
Fuel System pages 2.7 - 2.8 cover sync and fuel levels.
- shamal
26 Mar 2017 03:43Patton wrote: FSM If needed:
thanky you. fuel level its ok. one thing i have NEVER consider on ANY bike is the point at page 2-10. ''install the slide valve spring seat and turn the seat so that it doesn not block the hole in the bottom of the slide valve''
maybe i ever had fortune, but honeslty i think if this hole it's partially plugged by the spring seat, the carb will suffer when the gas is opened, or under load. maybe with a certain difficult at rising the slides, but i don't think this can affect the return to idle. or it can?
what you think?
the engine it's just running like a rocket...
1983 kz 550 h
26 Mar 2017 06:54
Has the physical carb sync (i.e., equal butterfly closures) been verified with vacuum gauges?
