Fuel Resistant Vacuum Caps
  • Nessism
  • Nessism's Avatar Topic Author
  • Away
07 Mar 2017 07:23
#756045
Stupid question, sorry, but I'm looking for some rubber vacuum caps to seal off three vacuum nipples on some carbs. Bought some vacuum caps from the auto parts store and they cracked after less than 6 months. Contacted Dorman and they said their caps are made of vinyl and won't hold up to direct gasoline exposure. What's the purpose of carb vacuum caps if they can't hold up to gas? The caps as sold by Kawasaki are something like $12/each and discontinued. Crazy. Plugging some ports shouldn't be this hard.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Fuel Resistant Vacuum Caps
07 Mar 2017 07:36 - 07 Mar 2017 07:41
#756047
No eBay APP ID and/or Cert ID defined in Kunena configuration www.z1enterprises.com/carb-holders-5-vacuum-plugs.html
or possibly
1982 KZ1100-A2
Last edit: 07 Mar 2017 07:41 by daveo.
The following user(s) said Thank You: GPz550D1, Nessism
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
07 Mar 2017 07:37
#756048
Back when I had 4 carbs on my bike vs 1 now with turbo I put clear fuel line on vacuum lines about 10 inches llong if memory serves me. I then plugged the fuel lines with plastic male fittings. I did this originally to make it faster to plug in my carb sync gauges. I would bundle and tie all 4 together and hide them under the tank. I also used fuel line and plugs threaded into my fuel bowls in the drain / jet change hole and it made it easy to purge any suspected bad fuel. They served as a remote catch can for moisture in fuel and this helped keep me running. Just a thought
Dave B) B) B)
  • KZB2 650
  • KZB2 650's Avatar
07 Mar 2017 07:39 - 07 Mar 2017 07:40
#756049
I was gonna say Z1 too but they are 10 bucks plus shipping and show outta stock..... I've been using a piece of fuel line with a screw screwed in the end for years and years with no problems..... maybe a little jury rigged but free and you can't really see em.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 07 Mar 2017 07:40 by KZB2 650.
  • JR
  • JR's Avatar
07 Mar 2017 07:39
#756050
Some years ago in a pinch I made my own using short pieces of black (1/4 inch ?) fuel line plugged at one end with a piece of grey 2 part epoxy. Mostly I just use the auto store ones. No problems
  • loudhvx
  • loudhvx's Avatar
07 Mar 2017 07:52
#756052
Yup, fuel line with a short Allen screw using the head as a plug. I do a lot of vacuum testing and have the plugs off and on a lot. The factory plugs start to lose tension and get loose after a few cycles. Making them costs about 5$ for20 or so.
  • mopguy
  • mopguy's Avatar
07 Mar 2017 07:56 - 07 Mar 2017 07:57
#756053
Reproduction Decals carries them , they are 5 for $12.00
www.reproductiondecals.com/default_frame...ml?content.html~main
Last edit: 07 Mar 2017 07:57 by mopguy.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Mar 2017 10:49
#756067
I like these, just ordered some.
  • Nessism
  • Away
07 Mar 2017 13:31
#756081
I found some of those K&L caps on ebay for $9 shipped so pulled the trigger. I'm not a fan of K&L parts but these caps seem low risk. Thanks to daveo for the tip on that P/N.
