And, and? Bend the tab ..
  • chopper1963
  • chopper1963's Avatar Topic Author
18 Jan 2017 08:51
#752424
Trying to figure out float height on a 1983 KZ750 L3.
Have the manual in PDF form.
Anyone know how this sentence about the tab on the float should end?
Thanks
  • missionkz
  • missionkz's Avatar
Re: And, and? Bend the tab ..
18 Jan 2017 10:03 - 18 Jan 2017 10:05
#752427
Probably something like ... lowers the fuel level in the float fuel bowl.
Bending the tab away from the needle will raise the fuel level in the bowl.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 18 Jan 2017 10:05 by missionkz.
  • martin_csr
  • martin_csr's Avatar
18 Jan 2017 10:11 - 18 Jan 2017 10:12
#752428
Here's a better version of the 750-4 manual. It's scanned very good & has a yellow/gold cover w color wiring diagrams.
Manual. 1980-84 KZ750-4. 1983-85 ZX750. 750turbo.com --- Index .
The pdf manual link is near the bottom of the list -->> GPz750 Base Manual.pdf. good scans.
PS: instead of bending the tangs, I would flex them x number of times. using a screwdriver to push on the tang & with the float bracket supported so that it wouldn't get mangled.
Last edit: 18 Jan 2017 10:12 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Jan 2017 10:19
#752430
Be careful not to bend them too much. Bend the float arms then the tang for fine adjustment. Too much and the needle will cock sideways and not seal.
  • Nessism
  • Nessism's Avatar
  • Away
18 Jan 2017 11:03
#752435
The fuel level is supposed to be 2-4mm below the gasket surface. Bend the little float tang until you achieve that level. I use a small screwdriver to bend the tang. When you work on the carbs upside down on the workbench the tang should be bend down by a small amount (5-10* down or so).
I'd start by setting the float height. Be careful to check to see if the weight of the float is compressing the needle though, and if it is you need to hold up the float before measuring. To measure you need to remove the gasket and measure to the carb surface as shown
