kZ900 Carb Size
  • TCKZ900
  • TCKZ900's Avatar Topic Author
kZ900 Carb Size
18 Jan 2017 04:36
#752404
Hey All... Ok I bought a 1976 KZ900 last spring. Pulled the carbs and they seem to measure 28 rather than 26 on the manifold side. Can anyone tell me if the 1976 ever came with the VM28's? Am I measuring correctly?
  • Nessism
  • Nessism's Avatar
Re: kZ900 Carb Size
18 Jan 2017 05:01
#752405
I don't know the answer to your question but I can say that the 26's measure a little oversize if you use calipers inside the outlets.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: kZ900 Carb Size
18 Jan 2017 06:10
#752408
I also don't know what you have, but if you do have VM28's on your motorcycle, then the carbs have been switched...All KZ900's (A4, A5, B1) came from the factory with VM26SS carbs.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kZ900 Carb Size
18 Jan 2017 06:10
#752409
They came stock with 26mm carbs. Pics?
  • Bama704
  • Bama704's Avatar
Re: kZ900 Carb Size
18 Jan 2017 07:21
#752415
Like everybody has said before, your bike came with 26mm carbs.
When I bought mine, the PO had switched the carbs to 28mm I have the late model off of a 1975 z1
1977 KZ900
Carbs are late model 1975 28mm
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kZ900 Carb Size
18 Jan 2017 07:44
#752418
The 28's are good carbs but the 26's stay in sync better. Not too much power loss.
  • TCKZ900
Re: kZ900 Carb Size
08 Feb 2017 11:51
#753933
Thanks everyone. I appreciate your time.
