My carb saga continues.
  • Setton
  • Setton's Avatar Topic Author
22 Dec 2016 13:08
#750595
So, I've been having a leak out of carburetor 3 (second from the right... assuming they're numbered 4, 3, 2, 1 from left to right). I thought it was flooding because it's been coming out of the overflow nozzle on the bottom of the bowl. However today I went and cleaned the needles and inside of the carb thoroughly. and I'm still having a leak issue.
I felt the outside of the bowl and there's gas on the outside of it. Where ever it's coming from, it's not coming exclusively out of the overflow nozzle on the bottom. I can't see where because it's one of the two carbs on the inside of the bike, not the outside, so the outside carbs are blocking my view.
I don't know how to figure out where it's coming out of and I'm out of ideas about how to fix this...
They're Keihin CV34 carburetors. They were re-done by Wired George earlier this year. I'm well past the warranty period however, because I didn't have everything I needed to get the bike to even start up again until just last month.
KZs I own
1982 KZ750-H3 LTD (frame's bent, no longer rideable, RIP)
1982 KZ1100 LTD Shaft (thought it was a Spectre)
1988 KZ1000 Police
1989 KZ1000 Police (basket case)
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
I don't understand soup. Put a flower on my nose.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: My carb saga continues.
22 Dec 2016 13:14
#750596
Do the clear tube test.
  • Nessism
  • Nessism's Avatar
  • Away
22 Dec 2016 15:46 - 23 Dec 2016 05:17
#750599
Only the 1980 KZ750 carbs have the floatbowls with a functional overflow feature. Your signature suggests you have a 1982 KZ750H model so what's up with that? Look at the photo below and tell us what type of floatbowl you have. The type with the tube sticking up have a functional overflow feature.
Typically when the float needles stick on the later carbs, the ones without the over flow tubes in the float bowls, the fuel fills up the carbs on the inside and the fuel pours out the float bowl vent passages on the inlet bellmouth opening of the carbs and then the fuel flows into the airbox.
[IMG
Last edit: 23 Dec 2016 05:17 by Nessism.
  • undiablo
  • undiablo's Avatar
23 Dec 2016 04:25
#750610
Yes, fuel flows to the airbox and drains through the bottom of it.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • Tyrell Corp
  • Tyrell Corp's Avatar
24 Dec 2016 17:53 - 24 Dec 2016 17:55
#750673
Not too scientific, but maybe open the drain and flush it on 'prime' maybe wash 1/4 a pint of fuel through it. Whack the offending float bowl with a rubber mallet, and repeat. Sometimes they just stick open.
If not then clear tube test - just a U tube manometer to check the fuel level. There is a kawi part number but it is just a graduated clear tube.
Worth checking fuel levels anyway - anything more than a couple of mm out of spec can cause issues.
edit: you want to change your oil too -that fuel will dilute it, entering the crankcase through the breather vent in the airbox..
Last edit: 24 Dec 2016 17:55 by Tyrell Corp.
  • spdygon
  • spdygon's Avatar
24 Dec 2016 18:16
#750676
Remove carb from bike ....set on table fill carbs with gas and see where gas is coming from. May have to leave over night if so stabilize then so don't to fall over.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • Setton
02 Jan 2017 15:43 - 02 Jan 2017 15:47
#751186
Nessism wrote: Look at the photo below and tell us what type of floatbowl you have. The type with the tube sticking up have a functional overflow feature.
The type on the left. I've got the bronze tubes sticking up. The originals I sent to WGCarbs didn't have it though.
Nessism wrote: Typically when the float needles stick on the later carbs, the ones without the over flow tubes in the float bowls, the fuel fills up the carbs on the inside and the fuel pours out the float bowl vent passages on the inlet bellmouth opening of the carbs and then the fuel flows into the airbox.
This happened on the original carbs when I first got the bike.
So I suppose the ones WG sent me were of an older model than the ones I sent him...
The leak seems to be coming from the bowl itself, because if I wipe my finger under the bowl (but not the overflow valve on the bottom) I get fuel on my finger. However above the bowl, it's dry... So it's basically coming out there in addition to the overflow nozzle...
I'm trying to scrounge up a way to mount the carbs off the bike so I can test the levels... I don't exactly have a good place to do it, and my landlord refuses to clean previous tenants stuff out of the garage so I can have room to do any real work.
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
Last edit: 02 Jan 2017 15:47 by Setton.
  • Setton
02 Jan 2017 15:55
#751188
Here's a photo of the inside of bowl from the offending carb. I don't know what the dark red stuff was. Might be ethanol, might be rust... I installed a filter and the stuff has stopped appearing in the bowl.
I found this photo on my phone from the first time I took it apart to try to fix this problem. Figured it can show that I do in fact have carbs of a different model than what my bike came with, given the above pictures...
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
  • Nessism
  • Nessism's Avatar
  • Away
02 Jan 2017 16:11
#751192
Looks like rust residue. Maybe rust in the tank is keeping the float needles from sealing?
  • Setton
02 Jan 2017 16:23
#751194
I thought it was rust too, which is why I put the fuel filter on, and since doing that it's stopped... The tank has been cleaned and gelled professionally just before putting everything back together, so I don't know how it could have gotten any rust in the lines, been but... I've blasted it all with carb cleaner and it couldn't be cleaner. Also, the red residue has stopped appearing in the bowls... and it's only this one carb, not the other 3, which is having this problem.
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
  • JR
  • JR's Avatar
02 Jan 2017 16:32 - 02 Jan 2017 16:35
#751195
It can be difficult to find the source of gss on the outside the bowl but if its carb #2 or #3 (left to right 1,2,3,4) there's a good chance it might be coming from the fuel inlet T fitting. The o rings on the T can dry up and leak.
Last edit: 02 Jan 2017 16:35 by JR.
  • Setton
02 Jan 2017 16:52 - 03 Jan 2017 06:44
#751205
JR wrote: It can be difficult to find the source of gss on the outside the bowl but if its carb #2 or #3 (left to right 1,2,3,4) there's a good chance it might be coming from the fuel inlet T fitting. The o rings on the T can dry up and leak.
If it's 1234, left to right, then it's carb 2 that's offending. All of the hoses and fittings are brand new, and they're dry when the engine is running. It's only the outside of the bowl that gets wet with fuel, not the carb body or the hoses.
The hose clamps however are the wire type, and they might be loose... So I'll check to see if any fuel is coming out of them, but I doubt it.
KZs I own
1988 KZ1000 Police
2002 KZ1000 Police
Non-KZs:
1983 Hondamatic 450
2001 Honda Rebel
Last edit: 03 Jan 2017 06:44 by Setton.
