Newbie here replacing original carbs 76 KZ900
  • Shelbygt
  • Shelbygt's Avatar Topic Author
03 Dec 2016 11:40
#749367
Old rider, new to the forum. Just ordered a set of 29mm smoothbores to replace originals on my 76 KZ 900. Got to thinking i might need to replace my intake manifolds too?
Any suggestions on vacuum gauges to synch carbs?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Newbie here replacing original carbs 76 KZ900
03 Dec 2016 11:45
#749368
If the old ones are hard or just old, replace them. Stock style will work fine.
The following user(s) said Thank You: Shelbygt
  • TexasKZ
  • TexasKZ's Avatar
03 Dec 2016 12:09
#749370
The Morgan Carbtune may be the best choice available since the death of mercury.
www.carbtune.com/carb.html
  • Shelbygt
03 Dec 2016 13:52
#749379
The reason I was asking on the intakes is I think the originals are 26mm. A jump to 29 seems like a lot. So it's just the inside of the carb tunnel that's bigger and the outside diameter is the same?
Did a little research and I think the Carbtune looks like the best one for the money. Glad you think so too.
  • spdygon
  • spdygon's Avatar
03 Dec 2016 14:11
#749380
The OD on the carb body are the same. The only difference is the inside.
When you say new...you mean new model or the old 29mm from back in the day?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • Shelbygt
03 Dec 2016 16:00
#749390
Old school. Didn't know they made them new?
Just bought a Carbtune 4 too.
Time to get me hands dirty again........
  • spdygon
  • spdygon's Avatar
04 Dec 2016 12:33
#749422
New are not same style of course but you can buy new 29mm Mikuni or Keihin
1974 Z1 900 project
  • TexasKZ
  • TexasKZ's Avatar
04 Dec 2016 14:25
#749435
