Carb Intake Boots
- Atlamillias
Carb Intake Boots
02 Nov 2016 15:52 - 02 Nov 2016 15:52
Sup guys. Really just looking for a subtle (or not) nudge in a direction here. Months ago I had questioned swapping my stock Mikuni BS34's CV carbs for VM28's.
Fitting whatever I've finished "tinkering" with back on the bike, and it comes time to fit it with appropriate intake boots, as the stock ones are about 30% larger around the carb. I haven't been very effective at searching for fitting boots. That being said, many of the intake boots sold online are simply replacements for stock boots, and don't list measurements.
Is there somewhere online I could compare parts with or something; maybe find one from another bike with close measurements? I have a really awkward feeling that if I were to add a spacer/gasket to occupy the space between my VM28's and the stock boots, it'll get sucked into the combustion chamber or something....
Last edit: 02 Nov 2016 15:52 by Atlamillias.
Re: Carb Intake Boots
02 Nov 2016 16:00
What bike is this?
02 Nov 2016 16:02
Didn't several models of the big KZ come with those 28mm VM carbs? What about using those boots and slotting the bolt hole as needed so you can fit them to your head?
- Atlamillias
02 Nov 2016 16:06swest wrote: What bike is this?
KZ750m Twin CSR
- Atlamillias
02 Nov 2016 16:08Nessism wrote: Didn't several models of the big KZ come with those 28mm VM carbs? What about using those boots and slotting the bolt hole as needed so you can fit them to your head?
Im a bit confused at what you're suggesting. Sorry, I I'm finding it difficult to visualize...
There weren't many CSR models made; i think 3 total? I couldn't find the measurements of the actual part on the other bikes.
- mopguy
02 Nov 2016 16:10 - 02 Nov 2016 16:11
Look in E-Bay for carburetor intake boots for Kawasaki KZ900/1000 years 1973 to 1980..
Last edit: 02 Nov 2016 16:11 by mopguy.
02 Nov 2016 16:12
That's what I thought. You'll have to do what Ed said and open them up where they meet the intake. You might try here.
jbmindustries.com/
Or see if they'll sell you just two.
www.diablocycle.com/Carb-Holders-Kawasak...1100-PM14-94001.html
jbmindustries.com/
- Atlamillias
03 Nov 2016 07:31
Ohhhh I think I understand. Buy boots that fit the VM28 carb and "rig" it to fit my bike?
03 Nov 2016 08:01
26-29mm carbs.
- Atlamillias
03 Nov 2016 11:12 - 03 Nov 2016 11:12
No eBay APP ID and/or Cert ID defined in Kunena configurationSo something like in the link would be okay?
Last edit: 03 Nov 2016 11:12 by Atlamillias.
03 Nov 2016 11:16
Looks like it. I'd be wary of NOS rubber. I've had bad luck with them. Call Diablo or the other places to see if you can buy two. About the same price for new if you can get them.
- Atlamillias
03 Nov 2016 12:40swest wrote: Looks like it. I'd be wary of NOS rubber. I've had bad luck with them. Call Diablo or the other places to see if you can buy two. About the same price for new if you can get them.
Perfect. Thanks a lot!
