Push/Pull throttle. Ditch the 2nd cable?
- slmjim+Z1BEBE
Re: Push/Pull throttle. Ditch the 2nd cable?
03 Nov 2016 07:38 - 03 Nov 2016 07:39toolmaker wrote: That second cable will work as the first if yours breaks on the road - just switch positions, :blink:
^ THAT ^
Also, consider that the cable on CV carbs are only rotating a shaft with butterfly plate(s) attached. On slide carbs, intake vacuum is constantly pulling the slides toward the intake ports, leading to increased friction.
We're considering purchasing a '75 Honda 250 thumper to run around town on. We noticed it has a slide carb with push/pull cables.
Personally, we want complete control of our throttle. If a slide sticks for any reason, we wanna be able to close it.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 03 Nov 2016 07:39 by slmjim+Z1BEBE.
03 Nov 2016 11:09
I've used mine as a spare when the original broke on the road.
- baldy110
03 Nov 2016 13:11
Removed my return cable in 1978 and have run it that way since. I have yet to hear of anyone ever having their throttle stay open on these. Now with that being said, I do run 2 cables on my ELR clone only because I am running RS36 flatslides on a warmed up engine. That engine produces so much vacume pressure when I let off the throttle after getting really hard on it that the slides will not return to idle on their own springs so I have to pull them closed. On a stock KZ650 / KZ1000 I wouldn't worry about taking off the 2nd cable.
- loudhvx
03 Nov 2016 15:33
Just need to make sure the return spring is in good shape and is the factory one, and the throttle assembly is working properly and lubed. It's plenty heavy enough to return the throttle. You don't need a new throttle assembly. Just remove the return cable.
I've only seen a sluggish closing throttle when both cables were installed, and not lubed properly.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- carwash
03 Nov 2016 18:39
this anything i should be interested in?
newjersey.craigslist.org/mpo/5855225412.html
1980 KZ550A
1980 CB750F
1980 CB750F
03 Nov 2016 18:50
- loudhvx
04 Nov 2016 10:46 - 04 Nov 2016 10:47The drivability would probably suffer. It could be too much carb for the stock Kz550 (non-gpz) motor. The intake ports in the head would probably need to be hogged out to really use those carbs. The ports are pretty closely matched to the stock TK22 carbs.carwash wrote: this anything i should be interested in?
They would be a nice collector's item, though, and if you ever swapped to a later-style motor (which have larger ports), it would be nice to have the bigger manual-slide carbs like that, instead of being forced to use CV's.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 04 Nov 2016 10:47 by loudhvx.
