KZ550 begins to sputter after 50 miles.
  • Kirkpatrick
  • Kirkpatrick's Avatar Topic Author
16 Oct 2016 17:45
#745382
After about 50 miles (after filling up), my 83 kz550a begins to sputter. If I put it on reserve, it comes back to life. My issue is that there is plenty of gas in the tank. I pulled over today after it started and it only took 1.7 gallons of gas. This is a regular event. It would seem to be a petcock thing but not sure. Any suggestions?
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: KZ550 begins to sputter after 50 miles.
16 Oct 2016 18:18
#745387
Next time it does it try lifting the fuel tank cap - maybe a tank venting issue?
Have you tried it with the tap on 'prime'
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Oct 2016 19:44
#745396
Could be a clogged strainer.
  • loudhvx
  • loudhvx's Avatar
16 Oct 2016 21:59
#745405
Do you have a see-through fuel filter with a paper element? If so, those cause problems like that. I rebuilt the petcock, but that didn't help. I had to go to a scintered bronze filter.
  • Kirkpatrick
07 Nov 2016 14:51
#747509
Actually, I will get a clear fuel filter and add that to the fuel line. I should then be able to figure it out. I will keep you posted.
1983 Kawasaki KZ550
1997 Honda CR500
