Identify KZ1000 Carbs
- mbougie
19 Sep 2016 10:12 - 19 Sep 2016 10:16 #742866
by mbougie
Identify KZ1000 Carbs was created by mbougie
Need help finding out what type carbs these are.. 26mm? 28mm? smoothbore? Off of 79 kz1000
Last edit: 19 Sep 2016 10:16 by mbougie. Reason: pictures wouldnt upload
- mbougie
19 Sep 2016 10:15 #742867
by mbougie
Replied by mbougie on topic Identify KZ1000 Carbs
pic of carbs
- Thank you received: 2840
19 Sep 2016 11:11 #742877
by Nessism
Replied by Nessism on topic Identify KZ1000 Carbs
Can you measure the throat inside diameter in mm on the exit side?
Those look like stock Mikuni's. I'm not sure what size though. 28's maybe.
The following user(s) said Thank You: mbougie
- Thank you received: 2755
19 Sep 2016 11:13 #742879
by SWest
Replied by SWest on topic Identify KZ1000 Carbs
26's. Good carbs.
- mbougie
19 Sep 2016 19:57 - 19 Sep 2016 19:58 #742954
by mbougie
Thanks so much. New the site everyone seems nice. Hope the stock carbs can handle the bore/stroke. Not sure how big the jets are.
Last edit: 19 Sep 2016 19:58 by mbougie.
- mbougie
19 Sep 2016 19:59 #742956
by mbougie
oh and i measured. They are indeed 26mm. Looks like the jets are pretty big. Building 79 kz1000 I think this site is going to help out alot. Thanks again everyone
- MDZ1rider
- Thank you received: 118
20 Sep 2016 13:18 #742992
by MDZ1rider
Replied by MDZ1rider on topic Identify KZ1000 Carbs
The jets should have a number stamped on them as well. Then you'll know exactly what size jet you're starting with.
