81 440 a ltd carb confusion
- Hyde_me
21 Aug 2016 15:26
I have a recent purchase of a 440 ltd that I am looking to use a a weekend escape pod from the family. Trouble is I can't get the carbs to any usable setting. I have pulled and cleaned the carbs twice with a 24 hour soak in carb cleaner and it seems to have not helped at all.
I can start the engine, the idle is set to about 1500 or so.
I turn the throttle lightly and the engine goes straight to 6000 and stays until I turn the bike off.
I have checked almost everything the maintenance guide.
Replaced both float valves as 1 would stick in
Replaced the rubber o rings on the pilot screws as one had ripped
Checked for leaks at idle around the carb boots
Still using factory air box
Please you have to help! If I have to spend anymore time with these people...... :blink:
Re: 81 440 a ltd carb confusion
21 Aug 2016 15:30
Pic of the bike? Have you checked the spark advance?
- Hyde_me
21 Aug 2016 15:51
This one has electronic ignition so is there any way to check the spark advance?
Attachment IMG_136.jpg not found
21 Aug 2016 15:53
CV carbs. Do you have a manual?
- Hyde_me
21 Aug 2016 16:02
I have the Factory Service Manual. but not the Clymer
21 Aug 2016 16:35
The spark advance is behind the points cover. Clean and lube it to be sure it isn't sticking.
- Hyde_me
21 Aug 2016 16:47
My timing looks like this. I have lubed this area with a light 3n1 oil
Attachment IMG_3007.jpg not found
21 Aug 2016 17:05
Looks great. Do a tune up. Valve adjustment timing etc before going to the carbs. CV carbs can have issues but these things must be done first.
Pics of the plugs?
Pics of the plugs?
21 Aug 2016 17:10Hyde_me wrote: My timing looks like this. I have lubed this area with a light 3n1 oil
Why is the pickup plate in that position?
- Hyde_me
21 Aug 2016 17:17
Did the valve timing (with the engine cold) and double checked
pressure check
new set of plugs
checked gap
checked spark with a inline tester
checked float bowl level with the clear tubing
pressure check
new set of plugs
checked gap
- Hyde_me
21 Aug 2016 17:18
That is not the actual, it is a pic from the net to show you what type I have
21 Aug 2016 20:50
Throttle cable hanging up?
