81 440 a ltd carb confusion
  • Hyde_me
  • Hyde_me's Avatar Topic Author
21 Aug 2016 15:26
#739403
I have a recent purchase of a 440 ltd that I am looking to use a a weekend escape pod from the family. Trouble is I can't get the carbs to any usable setting. I have pulled and cleaned the carbs twice with a 24 hour soak in carb cleaner and it seems to have not helped at all.
I can start the engine, the idle is set to about 1500 or so.
I turn the throttle lightly and the engine goes straight to 6000 and stays until I turn the bike off.
I have checked almost everything the maintenance guide.
Replaced both float valves as 1 would stick in
Replaced the rubber o rings on the pilot screws as one had ripped
Checked for leaks at idle around the carb boots
Still using factory air box
Please you have to help! If I have to spend anymore time with these people...... :blink:
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 81 440 a ltd carb confusion
21 Aug 2016 15:30
#739404
Pic of the bike? Have you checked the spark advance?
  • Hyde_me
21 Aug 2016 15:51
#739409
This one has electronic ignition so is there any way to check the spark advance?
Attachment IMG_136.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Aug 2016 15:53
#739410
CV carbs. Do you have a manual?
  • Hyde_me
21 Aug 2016 16:02
#739411
I have the Factory Service Manual. but not the Clymer
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Aug 2016 16:35
#739413
The spark advance is behind the points cover. Clean and lube it to be sure it isn't sticking.
  • Hyde_me
21 Aug 2016 16:47
#739414
My timing looks like this. I have lubed this area with a light 3n1 oil
Attachment IMG_3007.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Aug 2016 17:05
#739415
Looks great. Do a tune up. Valve adjustment timing etc before going to the carbs. CV carbs can have issues but these things must be done first.
Pics of the plugs?
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Aug 2016 17:10
#739416
Hyde_me wrote: My timing looks like this. I have lubed this area with a light 3n1 oil
Why is the pickup plate in that position?
  • Hyde_me
21 Aug 2016 17:17
#739418
Did the valve timing (with the engine cold) and double checked
pressure check
new set of plugs
checked gap
checked spark with a inline tester
checked float bowl level with the clear tubing
  • Hyde_me
21 Aug 2016 17:18
#739419
That is not the actual, it is a pic from the net to show you what type I have
  • TexasKZ
  • TexasKZ's Avatar
21 Aug 2016 20:50
#739436
Throttle cable hanging up?
