RS Flat Slide Pilot Jetting
- baldy110
Re: RS Flat Slide Pilot Jetting
02 Aug 2016 08:14
That all depends on what your final gearing is, what size are the rear and front sprockets, stock? I have mine geared a little high than stock, it tops out at around 145 mph at WOT. When I am really on the throttle I have to pay attention to the shift light it does come up really fast especially in the lower gears.
02 Aug 2016 08:14
Depends on what gear and how long. Watch those plugs in this heat.
- daveo
02 Aug 2016 08:34baldy110 wrote: That all depends on what your final gearing is, what size are the rear and front sprockets, stock? I have mine geared a little high than stock, it tops out at around 145 mph at WOT. When I am really on the throttle I have to pay attention to the shift light it does come up really fast especially in the lower gears.
This bike is a shaft-drive, and I don't know how top-speed relates to engine rpms. I believe with that bike in stock condition, top speed was claimed to be around 140 mph by Kawasaki. Would that speed have been achieved at redline, or WOT?
1982 KZ1100-A2
- daveo
02 Aug 2016 08:43swest wrote: Depends on what gear and how long. Watch those plugs in this heat.
Stay cool dude. :ohmy:
weather.com/weather/tenday/l/USCA0828:1:US
1982 KZ1100-A2
02 Aug 2016 13:02
I live outside of DHS.
weather.com/weather/today/l/USCA0295:1:US
Took a ride up to my daughters place and brought her a 30 pack.
weather.com/weather/today/l/USCA0856:1:US
cooler up here.
cooler up here.
- Kray-Z
- I need more power Scotty....
02 Aug 2016 14:18daveo wrote: Slept like a baby last night. Must have been that exhilarating ride down the highway...and back.
Wait a minute, maybe it was just a dream.........................................................zzzz......................................................................................
Nope. I actually made a surprising discovery about the air box, and PODS. Wake up Dave...slap! :pinch:
How can this be? All this time I was convinced, and the air box was restricting my pump.That square shaped little hole behind the filter was determined to keep out the good stuff, and was utterly successful at it. :evil:
Well zzz, enough of that!
Guess I'd better go have myself another look.
Later.
True - most stock air box inlets and filters are way too restrictive for a modified engine....
A proper large volume air box and filter(s), with properly tuned (length) bell mouthed velocity stacks inside the air box plenum, with ram air ducts to high pressure low temperature air, is the best of all...
K&N's are some of the best individual filters, and it does free up space and shed weight from the bike. They make getting the carbs in and out much easier, too. Sucks when it rains heavily, though...and remember to take a plastic bag or two with you when you go to a wand car wash or when leaving the bike parked outside in wet weather - to cover the filters.
- Kray-Z
02 Aug 2016 14:21baldy110 wrote: I have an 82 gpz 1100 with the 1170 kit, web cams ported head, and the rs36 carbs with pod filters. Mine carberates perfectly, very streetable. Starts easy, idles great, no flat spots, very smooth from idle to redline. I'm running 20 pilots, 135 mains with the needle clip in the 4th slot. It carberates perfectly from sea level to 12000 ft, from very cold to very hot temps. I'm extremely pleased with the rs carbs. And I get between 35 to 40 mpg depending on how aggressive I ride.
Very Nice - what a KZ was meant to be IMO! Love what you've done to the place!
- daveo
02 Aug 2016 16:34Kray-Z wrote:daveo wrote: Slept like a baby last night. Must have been that exhilarating ride down the highway...and back.
Later.
Great suggestions...
The air box must sit on the bench, for now.
In all the excitement I forgot about rainy weather and water intrusion.
Well, if I happen to get stuck in a storm...so be it.
1982 KZ1100-A2
- baldy110
02 Aug 2016 16:38
I've rode mine in several downpours and never had problems with water intrusion, still ran great.
- daveo
02 Aug 2016 16:47baldy110 wrote: I've rode mine in several downpours and never had problems with water intrusion, still ran great.
1982 KZ1100-A2
- daveo
02 Aug 2016 23:33 - 03 Aug 2016 05:37swest wrote: Depends on what gear and how long. Watch those plugs in this heat.
Reinstalled the .7 air jets to richen up the #20 pilot jets.
These carbs originally came with .8 air jets. Smaller richens, and bigger leans. :S
Plug appearance with pod setup after a couple long rides:
1982 KZ1100-A2
Last edit: 03 Aug 2016 05:37 by daveo.
03 Aug 2016 05:32baldy110 wrote: I've rode mine in several downpours and never had problems with water intrusion, still ran great.
+1
