Pingle Fuel Petcock , fuel line size ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
21 Jul 2016 18:28
#735774
Just received my Pingle dual outlet Fuel Petcock # 3311-D-AH. The fuel outlets measure 5/16" O.D. but my rubber fuel line measures 6mm I.D.. Not a problem to stretch and slide the existing fuel line over fuel outlets of Petcock, but will this size fuel line that I have " Impede " fuel flow all that much ? Bike is a 77' KZ1000A stock fuel tank with screw on male end ( 22mm nut ).
If I need to look for different fuel line I will.
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Pingle Fuel Petcock , fuel line size ?
21 Jul 2016 18:40
#735776
If the line will fit there shouldn't be any problems. Must be a tight fit.
  • kzdcw
  • 77' KZ1000A
21 Jul 2016 20:51
#735798
Line will fit ( very flexible ) and certainly will be tight enough. Thanks for the input.
I'm having my gas tank powder coated black with a clear coat. Looking for a different look.
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 Jul 2016 21:01
#735799
Be interesting to see what it looks like.
  • KZB2 650
  • KZB2 650's Avatar
22 Jul 2016 05:52 - 22 Jul 2016 07:19
#735816
Maybe search fuel line....... Goodyear makes a exc 5/16 inch fuel line ..... the Pingle is a high flow beauty of a petcock I wouldn't choke it down with 1/4 inch line. ;)............. whups should a read it better dual outlet guess 2 1/4s would be plenty.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 22 Jul 2016 07:19 by KZB2 650.
  • TexasKZ
  • TexasKZ's Avatar
22 Jul 2016 07:05
#735829
On a stock engine, two 6mm lines should provide all the fuel it can handle.
