KZ1100D2 Mystery Carb Parts
  • badams215236
  • badams215236's Avatar Topic Author
13 Jul 2016 20:17
#734861
Hello,
I've Got this KZ1100D2 that I am putting back together, it was not completely original when I bought it and I have found some ports on the slab of carbs that have me baffled. In this first Pic you can see the assembled carbs. the fuel line is down the middle and in-between both outside sets of carbs there is a barbed fitting that was open to the air when I bought it. my second pic show a close up the fitting in question.
Attachment WP_20160713_20_49_00_Pro[1].jpg not found
Attachment WP_20160713_20_49_10_Pro[1].jpg not found
Can anyone tell me what these ports are for. where they hooked up to in the stock config, and what should I do with them now?
thanks in advance for the info.
1983 KZ1100D2
Twin Cities, MN
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ1100D2 Mystery Carb Parts
13 Jul 2016 20:43
#734867
Looks like float bowl vents. Run a tube up above the air cleaner so critters won't get in.
  • TexasKZ
  • TexasKZ's Avatar
14 Jul 2016 18:18
#734981
Yup
  • badams215236
15 Jul 2016 13:49
#735061
Thanks for the info
1983 KZ1100D2
Twin Cities, MN
  • havakaw
  • havakaw's Avatar
14 Jan 2017 10:50
#752183
What is the specific name of these carbs? I know they aren't BS34's like on my 1100A Shafty.
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
  • Nessism
  • Nessism's Avatar
  • Away
14 Jan 2017 10:54
#752184
havakaw wrote: What is the specific name of these carbs? I know they aren't BS34's like on my 1100A Shafty.
They look like BS Mikuni's to me.
  • davido
  • davido's Avatar
14 Jan 2017 11:04
#752185
They look like my carbs (Mikuni BS).ive just finished overhauling them and fitted them today. The plastic T-Piece in the middle is the main feed which goes up to the larger fitting on the fuel tap.and the 2nd (smaller) pipe,is the vacuum and comes off the 2nd carb going up to the smaller fitting on the tap. The other 3 cabs will have the vacuum ports capped off.
Thats how i understand it.
www.wgcarbs.com//index.php?option=com_co...sk=view&id=Itemid=86
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • havakaw
  • havakaw's Avatar
15 Jan 2017 05:53
#752230
What I mean to say is that they only have 2 vent/jet holes in the rear air horn, and they have the center "T-Vents". The ones on my 1100 have 4 vent/jet holes in the rear air horn and NO center "T-vents". Are these an older version of the BS34 or do I have the correct name of mine confused? When I looked up the carb bodys in the parts microfiche for 1982 1100 A Shaft and 1100 Spectre, the carb bodies are definately different. Does anybody know what the specific differences are between the 2?
'80 KZ 750 LTD-H
  • Nessism
  • Nessism's Avatar
  • Away
15 Jan 2017 11:12
#752252
There are all kinds of variants of BS34's. Suzuki used the same carbs but there are several details where they are different from the Kawasaki version. They are still BS34's though.
