- Thank you received: 1
Air Suction System removal.
- carwash
Also, are there Carb boots available that don't have the vacuum port on them? I may be replacing those as well.
thanks!
1980 KZ550A
1980 CB750F
- carwash
www.cmsnl.com/products/holder-carburetor...651051/#.V4cCNbxlmnc
1980 KZ550A
1980 CB750F
- wrenchmonkey
- Thank you received: 75
My 550a arrived with this already "plugged" and there seems to be little or no magic involved. Just rubber caps on the carb, reed valve ports and air box.
Ironically, I went and replaced my carb mounts to get those vacuum ports so I could try out carb synchronizing. :laugh:
When I decided to remove all the emissions stuff on KZombie, I did things a little different; I connected the left reed valve port to the right reed valve port with a short (original) piece of tubing used by the system, even with stock spring clamps. The carb port was just blocked with a new rubber boot made for this and for the air box hole I had to get a little creative and found these rubber parts in the auto parts store that are made for replacing a master cylinder reservoir's cap/seal - basically a larger diameter rubber plug - and RTV'd it into position on the air box so it's not obvious and yet, still useable if later, I want to put the emissions system back on it.
- carwash
Did you connect the ports together for any reason other than the tube fit and it was an easy solution?
wrenchmonkey wrote: Are you are talking about the emissions reed valves?
1980 KZ550A
1980 CB750F
- Thank you received: 2237
The cleanest of all is to replace the cam cover with a non-US version that never had the setup.
- carwash
kzzone.com/billet.html
TexasKZ wrote: A cleaner looking way to do it is to replace the top of the reed boxes (the part with the hose barb) with a flat aluminum plate. APE makes them for the 900-1100 engines, but I suspect you will have to fabricate you own for the 550. It isnt difficult.
1980 KZ550A
1980 CB750F
- carwash
1980 KZ550A
1980 CB750F
www.partzilla.com/parts/search/Kawasaki/...X1100-A1)/parts.html
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
