- Thank you received: 36
Pod haters (and Pod lovers)
- Bowman
03 Jul 2016 15:08 #733721
by Bowman
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
Pod haters (and Pod lovers) was created by Bowman
So I've been shaking down my 750 B1 Twin. K&N pods, MAC 2:1 header and Supertrapp exhaust can, stock Mikuni CV carbs.
Tuned the Supertrapp as rich as it will go (1 disc). Turned the idle screws out an extra half turn and ...
It stumbles a little bit around 3500rpm, nothing serious, easy to avoid by throttling through it or upshifting. Used to pop and bubble a fair bit on deccelleration but stopped that after opening the idle screws. Got it up to 130kph/80mph on the highway and it was still pulling well. Thats as fast or faster than I will likely go at my advanced age. Plugs are as white as a KKK sheet which is the only thing that troubles me.
So it's running lean presumably but do I care as long as I just putter around town and occasionally ride at highway speed limits?
- Thank you received: 2755
03 Jul 2016 15:20 #733722
by SWest
Replied by SWest on topic Pod haters (and Pod lovers)
You don't want it too lean.
- Nebr_Rex
- Thank you received: 300
03 Jul 2016 19:04 #733736
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Pod haters (and Pod lovers)
Try the next size larger pilot jet and raise the needle with one washer.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Tyrell Corp
- Thank you received: 261
04 Jul 2016 05:04 #733758
by Tyrell Corp
Replied by Tyrell Corp on topic Pod haters (and Pod lovers)
I'd shim the needle first, then re-check the mixture. If still too weak go up one size on the main jets.
- Thank you received: 2840
04 Jul 2016 05:51 #733766
by Nessism
Replied by Nessism on topic Pod haters (and Pod lovers)
Pods lean the mixture far more than changes to the exhaust. You are most likely going to have to increase the main, lift the needle, and maybe even up the pilot jet too. Sounds simple but you can expect a lot of trial and error before getting it right. Good luck.
- undiablo
- Thank you received: 64
04 Jul 2016 06:15 #733769
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic Pod haters (and Pod lovers)
Try #50 slow pilot jet and #135 main jet.
- Bowman
04 Jul 2016 07:43 #733781
by Bowman
Replied by Bowman on topic Pod haters (and Pod lovers)
OK, I got the jet needles out and the little retainer clip can go down one more slot (richer). Worth trying that before shimming?
04 Jul 2016 10:19 #733802
by SWest
If the needles have slots, shims aren't needed.
