Stuck mixing idle jet
- Svendsen
29 Jun 2016 08:18
So i bought a used pair of carburetors but the mixing idle is stuck and previous owner tried to drill them out but in the wrong angle what could i do to get it out?
I thought about melting grease on top and use a stroke screwdriver?
Z650/ gsxr600 Cafézaki
- Svendsen
Re: Stuck mixing idle jet
29 Jun 2016 08:19Attachment karb.PNG not found
29 Jun 2016 12:53
You're going to have to file it flush, use a larger bit and center the hole.
29 Jun 2016 13:23 - 29 Jun 2016 13:23
One option is to cut a new slot with a dremel cut-off disc. Use a torch on the carb body around the screw and lots of PB Blaster (or similar) before attempting to turn the screw. Turn in both direction in an attempt to get it cracked loose. Once you do just keep rocking the screw both ways with heat and lots of pent. spray.
Last edit: 29 Jun 2016 13:23 by Nessism.
