Idles great, dies when giving it throttle
- Kateri66
1982 KZ440 LTD (A1)
- Thank you received: 2755
- Thank you received: 2237
- Kateri66
1982 KZ440 LTD (A1)
- Kateri66
1982 KZ440 LTD (A1)
- Kateri66
Attachment IMG_20160610_090225(1).jpg not found
Gads! Didn't realize that was so big! Sorry folks!
1982 KZ440 LTD (A1)
Has the bike run properly since you have owned it?
- Thank you received: 2840
BTW, those intake manifolds are not stock. Any air leaks in said manifolds will throw off the fuel mixture and make the bike run like crap.
- MDZ1rider
- Thank you received: 118
- sketch
sketch wrote: My 83 550M1 with CV carbs was doing this as well last week. Are you running with the stock airbox or pod filters? Either way - if they aren't mounted/on, throw them on. I threw on my pod filters and let it warm up a bit longer (10-15 minutes or so total?) and the issue went away for me.
If you don't rejet after installing pod filters your engine will be running drastically lean, and that causes heat and (likely) subsequent engine damage.
