More carb id fun, vm26 or 28
  • MadShad
  • MadShad's Avatar Topic Author
04 Jun 2016 08:47
#730005
Vm26 or 28?
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: More carb id fun, vm26 or 28
04 Jun 2016 08:57
#730007
28 just like mine.
The following user(s) said Thank You: MadShad
  • MadShad
04 Jun 2016 09:05 - 04 Jun 2016 09:06
#730009
Thank you, the only marking I could find was
127
0
This thing has 20 pilots and 140 mains, I'm new to the larger bikes but that seems excessive.
Found 2 bent float pins and a clogged pilot when I cracked them open.
Shows signs of running VERY rich, this bike is a complete unknown so ill be busy today.
Last edit: 04 Jun 2016 09:06 by MadShad.
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Jun 2016 09:27 - 04 Jun 2016 09:28
#730010
I had 17.5 pilots and 125 mains. That's with 1X Andrews cams. Stock is 117.5 mains. I'd go 120.
Taking a ride to my daughter's and will pick up a new Shinko 130/90-18 tire on the way back. I'll check in later.
Last edit: 04 Jun 2016 09:28 by SWest.
