And... I'm stuck kz550 TK22
  • Brick123c
  • Brick123c's Avatar Topic Author
03 Jun 2016 12:38
#729874
Hey guys first time cleaning a carburetor and I'm not sure where to go from here. I pretty much just have the caps off and I'm not sure what to do next. If anyone knows where a video or step by step instructions are please lmk!
1982 Kz550
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Brick123c
Re: And... I'm stuck kz550 TK22
05 Jun 2016 08:46
#730166
Is there any other option for me rather than spending 90 dollars on ordering oem gaskets for the carbs ? The guy before me used rubber gasket
1982 Kz550
  • Brick123c
05 Jun 2016 08:46
#730167
Can I make them out of a cutout ?
1982 Kz550
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • missionkz
  • missionkz's Avatar
07 Jun 2016 19:15
#730479
Brick123c wrote: Is there any other option for me rather than spending 90 dollars on ordering oem gaskets for the carbs ? The guy before me used rubber gasket
Don't waste much, if any, money on buying bew brass parts, like jets, needles, seats... Etc.
I have yet to see hardly any of those parts ever really need replacement .... Especially on bikes under 20,000-30,000 miles.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Jun 2016 19:23
#730481
Only if they're munged up by the PO.
  • martin_csr
  • martin_csr's Avatar
08 Jun 2016 10:39
#730581
PartsnMore.com has float bowl gaskets for the 550C Ltd. I don't know if they are paper or rubber. $4 each. I've placed a couple of orders with them in the past year. I get most of my stuff from Z1Enterprises.com, but I did not see the bowl gaskets for your bike.
Other stuff. loudhvx has a motorcycle stuff page with a bunch of KZ550 & TK22 info. be sure to read up on the choke flaps, as they can come off & get sucked into the engine. I think someone here on KZR reported that recently. I don't know if there's a preventative repair or what.
  • loudhvx
  • loudhvx's Avatar
13 Jun 2016 10:19
#731211
...mostly just inspection. The hinge curls break off one at a time. You can inspect them easily without removing the carbs. Just pull the tops off and remove the choke plate bell-crank screws. The hinge curls will develop what looks like a line parallel to the axis of the hinge. That develops into a crack, then the hinge curl breaks off. Later the second one will break off. Then the flap is free to go through the motor. You just have to make sure the curls look good and are both intact. The hinge pin also tries to walk out. That needs to be staked back in, very carefully as the casting very brittle. The pin won't come all the way out because the carb body captures it, but the pin can be loose which contributes to the flaps cracking.
