Carb repair kit for unidedtified carb set
- Apets1100
01 Jun 2016 22:55
Hello everybody
I have a z1100GP converted to carbs. The carbs that are on the bike are BS34 but I don't know the bike model that they came of. Trying to find a solution on that because I need to buy a repair kit for them. Is there a database with photos or some kind of identification numbers, somewhere? or any other kind of solution? These are my carbs in the photo. I can upload other photos if necessary...
Attachment bs34.jpg not found
Tony
GP1100z B2
GP1100z B2
Re: Carb repair kit for unidedtified carb set
02 Jun 2016 08:15 - 03 Jun 2016 04:44
From the diagrams at Partzilla I think most if not all of the 81-on KZ1000/1100 models used the same carbs, including
the 82-2005 KZ1000-P police bikes (not the 81 1000-C4 police). The primary differences are probably in the jets.
I wouldn't necessarily buy carburetor kits as they usually cover a range of models, so you can end up paying for extra unneeded parts. you may only need to replace the gaskets & rubber parts. Z1Enterprises.com probably has the stuff you'd need. I would clean the carbs & inspect everything, then place an order.
I compared various parts of an 81 1000 & 2005 1000P and the stuff I checked was the same. same floats & float valves, bowl gaskets & pilot jet plugs, and the pilot air screws etc are the same. the vac slide valves had different part numbers.
I did not compare the jets. you could compare other stuff.
Last edit: 03 Jun 2016 04:44 by martin_csr.
02 Jun 2016 08:35
02 Jun 2016 10:11
Cycleorings.com sells a BS CV carb O-ring kit that's very useful. Reuse your old floatbowl gaskets or get some new ones as necessary from the likes of Z1 Enterprises. As for jetting, I'd get a Dynojet kit from a similar year KZ1100, and also make sure the pilot jets are the correct size.
zeus.mtsac.edu/~cliff/storage/gs/Mikuni_...Rebuild_Tutorial.pdf
- Apets1100
03 Jun 2016 00:30 - 03 Jun 2016 00:32
Thank you all for the quick and helpfull replies. I'll start opening the carbs today and see what I'll find.. I was unable to even start the bike for the last 3 years, so maybe there are noumerous plants and alive creatures in those bouls... I looked in Z1 enterprises and found a set that seems ok, it has two numbers of jets 120 & 122,5. Can I presume that theese numbers are close to the standard that bike had from the factory?
I'll check mine to see what number they are..
I looked in cycleorings and jetsrus, very helpfull.
Also sorry for my poor english, I hope that it'not all looks like greeks to you! I'm from Greece..
Tony
GP1100z B2
GP1100z B2
Last edit: 03 Jun 2016 00:32 by Apets1100.
