cleaning carbs without removal
- undiablo
Re: cleaning carbs without removal
03 Jun 2016 05:35
Like drmiller100 told you, pilots are blocked.
The best solution would be to take the carbs out and fully clean them.
However, one time I got away with this:
Empty the tank. Fill with new gas. Put a full botlle/can of injector cleaner (disregard manufacturer recommendations). Empty carb bowls using the drain screw, let them fill with new gas+cleaner.
Fire the bike and try to keep it alive by any means. Stop. Do it again. Stop.
Let it seat over night.
Next day there is a good chance pilot will be functioning again.
At least this happened to me one time on my KLR650.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
The following user(s) said Thank You: Maninthebox1064
- undiablo
03 Jun 2016 05:38
By the way, last year I have succesfullyu removed al 4 pilots jets with carbs installed in the bike (Keihins CV34).
Takes patience, but is doable.
- Skullcrusher
03 Jun 2016 17:58
Pull carbs. It's idiotic to spend an hour working around something that takes ten minutes to do.
Don't forget to remove idle mix screw and spray carb cleaner and compressed air through all passeges and jets.
Bikes: 82 kz750 CSR, 03 Suzuki gsf1200s (stage 2), 73 CB 750 bored to 849, big cam, ports head, big valves, lots of other goodies....
The following user(s) said Thank You: Maninthebox1064, drmiller100
- kaw-a-holic
03 Jun 2016 18:10
Take your time do it right by yourself a field service manual or see if you can download one here or somewhere else have you looked in the archives to download one here? If you want the bike to run right you need to take the carbs off and do a thorough cleaning otherwise you're just wasting your time. I know it's scary but if you think about it, none of us here were born with the information that we possess now about motorcycles we all had to learn somewhere at some time.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
03 Jun 2016 18:21
After it's all said and done, "there's a certain satisfaction in knowing what's going on in between your legs" :woohoo:
- Maninthebox1064
04 Jun 2016 18:00
Thanks for all of the suggestions! I am going to start by pulling the carbs and cleaning them.
I also got new fuel lines and plan to install fuel filter(s) but I have another question on this topic.
Do I need 4 fuel filters or will one work? I saw another thread where a person installed 1 filter per carb on a kz750 twin and I didn't know if that was the right way of doing it. I haven't messed with filters yet so this is a completely new topic to me.
04 Jun 2016 18:05
One fuel filter is fine. Run the fuel line from the tank to the filter then from the filter to the carbs. Ed
04 Jun 2016 18:05
One per fuel line and a manual.
