1983 kz1100 spetra PLS HELP
  • Mikesimon
  • Mikesimon's Avatar Topic Author
30 May 2016 07:55
#729204
Shooting gas threw exhaust ,going down the rode it misses for a sec then kicks in.But it runs out of gas fast .PLS help
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1983 kz1100 spetra PLS HELP
30 May 2016 08:01
#729206
Check valve adjustments.
  • Mikesimon
30 May 2016 08:10
#729208
I will thank you .
  • Mikesimon
30 May 2016 08:12
#729209
I will thank you .he'll it caught fire on the headers.scared the shut out of me
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2016 08:22
#729211
Pics of plugs?
  • Mikesimon
30 May 2016 09:01
#729215
Give me a sec
  • Mikesimon
30 May 2016 09:30
#729219
Attachment 20160530_123011.jpg not found
Attachment 1464625901620-480011979.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2016 09:44
#729220
Stuck float?
  • TexasKZ
  • TexasKZ's Avatar
30 May 2016 19:28 - 30 May 2016 19:30
#729290
If you can see raw fuel shooting out the exhaust, there is a serious problem, probably in the carbs.
Is this a new problem? Has anything been done to the motorcycle recently, like removing parts or messing with the carbs, or fuel system, or anything else?
Has any of the routine maintenance been done?
Last edit: 30 May 2016 19:30 by TexasKZ.
  • Mikesimon
30 May 2016 19:51
#729293
Man I drain the oil and it was almost pure gas.Crazy .I bought bike from a old man he had it cor 20 years .I drove it for three days ,i lowerd it put staight handle bars,and a radar detector.then it lost all power .the yellow and black wire from coil to switch was not hooked up .I fixed that and now it spits and sputters when you first but the throttle. Then it kicks in like a power band .but a tank a gas last about 5miles . I just can't figure it out .would it be the wiring
  • TexasKZ
  • TexasKZ's Avatar
30 May 2016 20:21
#729298
Fuel in the oil is a sure sign of a float valve and petcock problem. The petcock should stop the flow of fuel when the engine is off and the float valves should stop the flow of fuel when the carb bowl is full. Both need to fail to have fuel flow into the cylinders and into the crankcase.
  • rrsmsw9999
  • rrsmsw9999's Avatar
30 May 2016 20:43
#729301
God sakes man! You're gonna blow yourself up. Get the tank off and stop running it until you fix it. Hope you're safe. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
