- Thank you received: 50
83 KZ1100 Shaft Air box plug for reed valve hose
- jdvorchak
21 May 2016 14:59 #727785
by jdvorchak
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
83 KZ1100 Shaft Air box plug for reed valve hose was created by jdvorchak
PO had done away with the vacuum switch that goes from the reed valves to the air box. There is one hose that just connects each reed valve cover to each other. That leaves a big hole in the air box. Just wondering if I plug the hole? I can't imagine what harm it would cause and it plugs the fresh air source to the carbs.
John
83 KZ550M1
83 KZ1100LTD
Also own:
- Thank you received: 2755
21 May 2016 15:01 #727786
by SWest
Replied by SWest on topic 83 KZ1100 Shaft Air box plug for reed valve hose
Plug it.
The following user(s) said Thank You: jdvorchak
- jdvorchak
21 May 2016 15:40 #727789
by jdvorchak
John
83 KZ550M1
83 KZ1100LTD
Also own:
Replied by jdvorchak on topic 83 KZ1100 Shaft Air box plug for reed valve hose
Thanks Steve. I used a wine bottle cork for now...
John
83 KZ550M1
83 KZ1100LTD
Also own:
- Thank you received: 2840
21 May 2016 21:47 #727835
by Nessism
Replied by Nessism on topic 83 KZ1100 Shaft Air box plug for reed valve hose
