- Thank you received: 13
Possibly oil in fuel ?
- kzdcw
- 77' KZ1000A
13 May 2016 18:22 - 13 May 2016 18:42 #726273
by kzdcw
77' KZ1000A
Possibly oil in fuel ? was created by kzdcw
I just rebuilt my Starter/clutch assembly and replaced the cracked rotor off my 77' KZ1000A. Steve and a few other members gave me good advice in repairing the problem and I appreciated that !
I have the stock carbs. on my bike and were cleaned well and adjusted. Even though I'm running the K&N dual air filter pods on the bike and have jetted them pretty close, I'm noticing that from the fuel overflow tubes that the fuel appears to be a little oily ?
Bike was a basket case when I first purchased it, but have gone thru all the mechanicals and electrical and have pretty much sorted them out. The stock exhaust was gone, so running a Vance and Hines 4 into 1 and sounds real nice.
Bike starts up real nice with no signs of blue smoke at start-up, only a little oil residue in the fuel when I run my fingers under the overflow external nipples at the bottom of the float bowls.
Any ideas ???
Also, would backing out the fuel mixture screws at the carbs. make the bike a little easier to start ? I believe counterclockwise out makes it the fuel mixture richer?
Any ideas ???
77' KZ1000A
Last edit: 13 May 2016 18:42 by kzdcw.
- Thank you received: 2755
13 May 2016 18:42 #726284
by SWest
Replied by SWest on topic Possibly oil in fuel ?
Pics of your set up?
