29 s or 34s?????
  • Tirefire Pat
  • Tirefire Pat's Avatar Topic Author
  • (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
29 s or 34s?????
10 May 2016 09:42
#725532
hey guys my previous 80 1000 b had a bunch of motor work done.cams,bored over, v& h clutch.Barnett springs,welded crank..ported...OK here's my question.. I had 29 mm smoothbore s on it..it freekin was a screamer!!!!! 11 sec 1/4. Fast forward 25 yrs. I have another 80 1000 b..,..talked to same mechanic that built first one, he recommended 34 mm carbs ,,wat do you guys think..?????new bike has o upgrades ..but they are in my plan...i m starting to gather parts for the project.. Which way should I go????thanks for any help..Pat
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 29 s or 34s?????
10 May 2016 14:15
#725570
The 34 is a more modern carb. The 29 and 33's were hard to tune.
The following user(s) said Thank You: Tirefire Pat
  • TexasKZ
  • TexasKZ's Avatar
10 May 2016 15:03 - 10 May 2016 15:04
#725586
That kinda depends on which 34s you are asking about. BS? RS? CR? CR-S? Weber? SU?
Last edit: 10 May 2016 15:04 by TexasKZ.
  • DFIGPZ
  • DFIGPZ's Avatar
10 May 2016 15:37
#725592
Mikuni RS34 Hands Down.
1984 750 Turbo
