RS and VM drain plug removal
- daveo
22 Apr 2016 12:54
How can I minimize fuel spillage while removing the bowl drain plugs on these carbs?
1982 KZ1100-A2
Re: RS and VM drain plug removal
22 Apr 2016 13:27
For draining my VM24SS carbs I cut a section out of the side of a plastic soda bottle and held that under the drain plugs to catch the fuel when I removed the plugs. Be POSITIVE that the petcock is turned off before removing a drain plug; and remember - NO SMOKING!
- daveo
22 Apr 2016 14:10650ed wrote: For draining my VM24SS carbs I cut a section out of the side of a plastic soda bottle and held that under the drain plugs to catch the fuel when I removed the plugs. Be POSITIVE that the petcock is turned off before removing a drain plug; and remember - NO SMOKING!Ed
Thinking ahead to when the carbs will be on the bike, and just how messy those little buggers could be to drain.
Do the plugs need to be completely removed, or just loosened a bit?
1982 KZ1100-A2
22 Apr 2016 15:04
They have to come off. The bottom of a milk jug about 2" deep should do it.
- redhawk4
22 Apr 2016 16:34
If the bike is running, turn off the petcock and run them as close to dry as possible then at least there's much less fuel to contend with. It's also a good outside job so if any does spill, it will evaporate rather than stinking the garage or shed up.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
- daveo
22 Apr 2016 19:38swest wrote: They have to come off. The bottom of a milk jug about 2" deep should do it.
Makes the BS34 seem pretty user-friendly with the drain screw/nipple setup on the bottom of the bowls...
1982 KZ1100-A2
22 Apr 2016 20:20 - 22 Apr 2016 20:23
There already is a drain hole about half way up (at least there is on the VM24carbs). Ed
Attachment 00003b-2-3-4-5-6-7-8-9.jpg not found
Last edit: 22 Apr 2016 20:23 by 650ed.
22 Apr 2016 20:55
They have large caps over the main jets.
- daveo
23 Apr 2016 02:06 - 23 Apr 2016 05:50
Not on these for some :S reason. These plugs use an o-ring to seal against the bowl.
Well, I guess its time for another experiment...
Below is a (very-nice) version of the plug currently available on ebay, with no holes either:
650ed wrote: There already is a drain hole about half way up (at least there is on the VM24carbs). Ed
1982 KZ1100-A2
Last edit: 23 Apr 2016 05:50 by daveo. Reason: revise and add content
- KZB2 650
23 Apr 2016 07:48
I always use a good sized rag to catch what ever the home made bowl misses too...... my drain plugs got so loose on my smooth bores I had to replace em..... lotta winter draining and jetting........ seems the bowls were made outta slightly better material cause the new plugs tightened things up again..... stockers are fine as they've only been run 7 or 8 years.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- daveo
23 Apr 2016 13:51
I wouldn't.
