93 KZ1000P Rebuilt Carbs not starting
  • smyrnasurfin
  • smyrnasurfin's Avatar Topic Author
Re: 93 KZ1000P Rebuilt Carbs not starting
25 May 2016 03:02
#728371
i backed off the pilot screws 3 turns and still no fuel. I am going the to check the passage ways up to the pilot screw and see if the issue is there. It seems odd though that after a complete clean and rebuild by a mechanic that all 4 carbs are clogged in the same place.
  • drmiller100
  • drmiller100's Avatar
25 May 2016 07:45
#728423
my 81 1100 won't start without a shot of ether.
once running, it has a huge hanging idle.
when I spray either on the boots, it revs up drastcially. I ordered the 4 boots between carbs and engine,
I'm hoping the boots are rotted out and leaking, and has enough leaks the choke circuit doesn't work while cranking.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 May 2016 08:23
#728434
They'll leak at the head first. You don't see it there.
  • smyrnasurfin
25 May 2016 12:11
#728487
Boots leaving the airbox and going into the cylinder are solid. Vacuum lines new. I can hold my finger over a disconnected vacuum line and I can feel suction when cranking.
  • smyrnasurfin
31 May 2017 06:50
#763148
Sad I know, I had to put the troubleshooting on hold because I bought a daily driver that turned into another project.
It's been a year and hopefully I can return to this issue. Either that or it goes to the dealer before it is beyond repair.
