78 kz400 c1 help!!!
  • Drafter89
  • Drafter89's Avatar Topic Author
78 kz400 c1 help!!!
18 Apr 2016 16:31 - 18 Apr 2016 16:35
#721633
This all happened after I replaced my negative wire that goes to my frame so this might be an electrical topic...idk, but something is telling me its a fuel delivery issue. Fired my bike up and it sat at idol just fine and seemed to be ok. I shut it off after it warmed up. Tried to fire it back up again and it took me about 20 minutes of kicking to get it started again and it kept back firing really loud!! It seriously sounded like a shotgun going off. Now it won't start at all and just keeps backfiring. I have spark, idk what it could be. It ran just fine before I don't get it??? Oh, I have an aftermarket exhaust on it without the baffle in and the carb has been rejetted. And it also got really hot here lately where im from idk if that gas something to do with it? Its ran fine for months. Please help??
78 KZ 400 C1-Daily Driver
New Albany,IN
Last edit: 18 Apr 2016 16:35 by Drafter89.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 78 kz400 c1 help!!!
18 Apr 2016 16:39
#721635
I sound like a broken record but have you checked the valves? Also the spark advance, points?
  • Drafter89
18 Apr 2016 16:45 - 18 Apr 2016 16:46
#721638
I thought about that but with my experience i wasn't sure if that could be apart of the problem. No I have not. I'm going out there to check right now.
swest wrote: I sound like a broken record but have you checked the valves? Also the spark advance, points?
New Albany,IN
Last edit: 18 Apr 2016 16:46 by Drafter89.
  • jdvorchak
  • jdvorchak's Avatar
19 Apr 2016 05:09
#721699
If this were a 4 cylinder engine I'd say you have two plug wires crossed. but since this is a 2 cyl ?
Try removing both plugs and kicking it over a few times, with the throttle wide open and fuel shut off, just in case you have it really flooded.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • martin_csr
  • martin_csr's Avatar
19 Apr 2016 06:58
#721725
Is the new ground wire the same as the old & did you install it exactly the same?
And is it grounded to the frame or to the engine?
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
19 Apr 2016 07:02 - 19 Apr 2016 07:03
#721728
If it ran fine before replacing the neg cable then it's something you did, or disturbed. Is the battery fully charged? My Z1 runs like crap with a bad battery.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 19 Apr 2016 07:03 by Kidkawie.
