- Thank you received: 23
Fuel inlet 'T-pipes'...
- Rockranch
Attachment 1976carbsKZ900carbs001.jpg not found
Vroom-vroom!!!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
- Thank you received: 797
the aftermarket fuel t's use an o-ring to seal.
i have a set of the billet ones on my carbs on my 80 z1r.
on one set of my carbs before the aftermarket caught up .i cut the rubber back with a razor and installed o-rings on the modified t's and it worked until the o-rings got old and cracked.
- Thank you received: 2829
- Rockranch
Vroom-vroom!!!
1 modified
- bluej58
- Thank you received: 511
I soaked the original T's from a nasty looking set of 77- 26VM in gas while I was rebuilding the carbs.
I know they haven't been used for 35 years and they are working as they should.
78 KZ1000 A2A
- z1kzonly
- Thank you received: 542
Plus I always used teflon tape for years. That fixed it for me. Wrap 3 or 4 times with the tape
I never bought new ones.
- GKBO
- Saving old"dead" bikes
- Thank you received: 10
- z1kzonly
Excellent craftsmanship! He might already have them. Check his items.
I have purchased several of his items!
He's out in Montana.
www.ebay.com/sch/gunsbluemoon/m.html?ite...rksid=p2047675.l2562
- Rockranch
Vroom-vroom!
1 modified
- z1kzonly
If you do get in to more like taking the needles out of the slides.
Make sure you got a new perfect fitting #2 phillips or JIS bit. Those screws give ya trouble sometimes
- Rockranch
Thanks for that link. ................................Mikez1kzonly wrote: Here you go! Here is the machinist that started out making fuel level tubes. Send him a request for what you need.
Vroom-vroom!!!
1 modified
- Rockranch
Ya true that is...good point, been there done that. I found years ago that grinding just a fraction off the tip of a standard phillips screwdriver gave it a much better fit and had much fewer problems with Jap-made screws. .........................Mikez1kzonly wrote: Heck, 26mm are simple, 28mm's are a pain.
Vroom-vroom!
1 modified
