Magnet to fuel filter? Rust dust.
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
27 Mar 2016 16:35
#717641
I opened up bowls again after 30 miles of riding and they had rust dust again!
I remember washing bowls with break cleaner first time.
Filter doesn't catch rust dust. If rust is magnetic, small magnet will catch it and I will see it thru clear fuel filter.
I always buy small fuel filters from NAPA.
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: Magnet to fuel filter? Rust dust.
27 Mar 2016 16:55
#717644
How fine of a particle size do the NAPA filters claim to block? Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Mar 2016 17:55
#717652
What kind of gas do you buy? They say if the truck is there filling the tanks, go somewhere else.
  • bountyhunter
  • bountyhunter's Avatar
28 Mar 2016 00:02
#717712
car5car wrote: I opened up bowls again after 30 miles of riding and they had rust dust again!
In the 37 years I have owned mine, I can not remember a single time I dropped the bowls on my carbs and did NOT see some rust dust sediment in there regardless of what filters I used.
  • Nessism
  • Nessism's Avatar
  • Away
28 Mar 2016 07:40
#717735
Clean the fuel tank. Seal it if necessary. Fuel filters that flow easily at 0 psi like our bikes require are not going to filter the fuel down to some low micron level. The common gold stone filters are more like a strainer than a filter. Paper filters work better but typically need positive fuel pressure to push the fuel through.
  • loudhvx
  • loudhvx's Avatar
28 Mar 2016 08:10 - 28 Mar 2016 08:11
#717740
swest wrote: What kind of gas do you buy? They say if the truck is there filling the tanks, go somewhere else.
They said that back in the days when the gas station's underground tanks were made of steel. But I think most stations are now some composite material, or at least lined with some inert material. Plus there's no way to tell if the tanker just left a minute before you got there.
Last edit: 28 Mar 2016 08:11 by loudhvx.
  • loudhvx
  • loudhvx's Avatar
28 Mar 2016 08:13
#717742
Same here. It does not seem to mess anything up, really, it just sits in the bottom of the bowl. I will drain the bowls once or twice a year after a ride. Hopefully if the rust is stirred up from the ride, it will come out with the gas.
28 Mar 2016 08:13
#717743
Here's what I use on my KZ650. The Golan filter filters at the 10 micron (.000392") level. Those are pretty small particles. Ed
www.kzrider.com/forum/3-carburetor/59406...ne-and-filter#633243
  • loudhvx
  • loudhvx's Avatar
28 Mar 2016 08:14
#717744
Nessism wrote: Clean the fuel tank. Seal it if necessary. Fuel filters that flow easily at 0 psi like our bikes require are not going to filter the fuel down to some low micron level. The common gold stone filters are more like a strainer than a filter. Paper filters work better but typically need positive fuel pressure to push the fuel through.
+1
