Feul injection?
- AjKZBobber
- New KZ rider...Long time dirt biker
My most recent issue is that it idles great, buy cuts out under load. I know this means I'm running lean, but I'm at the point where I'm working on it more than riding it. It's always something.
My question is, would it be worth it, or even possible, to switch the bike over to an injection system. If so, hire would I go about this?
Any help would be great. I really enjoy the bike when it's running, but that's a rarity anymore.
1979 kz750 b4 twin bobber
- Thank you received: 2829
- bluej58
- Thank you received: 511
78 KZ1000 A2A
- GPzEric
- Thank you received: 31
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
- Thank you received: 2098
When symptoms appear, test run with the fuel cap ajar (loosened and not fastened down) to assure sufficient venting.
Was an aftermarket in-line fuel filter installed before any gasoline was allowed to enter the freshly cleaned carbs?
If not, it's likely that the carbs were quickly re-contaminated by rust particulate in the incoming gasoline.
- wrenchmonkey
- Thank you received: 75
AjKZBobber wrote: So, I have a 1979 kz750 twin ..(snip) it will run great for a couple weeks after. But then, it starts running crappy again. ...
- The_Proletariat
- "Cocaine is a hell of a drug"
- Thank you received: 13
Sure fuel injection is possible. Source suitable throttle bodies, injectors, and some way to attach them to the head. Get a fuel pump. Create some sort of crank trigger, maybe off a cam lobe. Perhaps a microsquirt to control it all.
Fixing your carbs will be much less work.
1982 Kawasaki KZ550 LTD
- theApehouse
- Thank you received: 11
1987 KZ1000P, dynatek 2.2 coils
www.youtube.com/channel/UC3VtY1XWwKH3zK2trI2Hz1w
- AjKZBobber
- theApehouse
Places I have bookmarked are:
www.useasydocs.com/quickstart.htm
www.diyautotune.com/support/tech/install/
forums.hybridz.org/topic/56329-megasquirt-overview-for-newbies/
www.fintechcommunications.com/funstuff/
www.msefi.com/index.php
From a different medium, I found this book to be incredibly insightful, down from the basics, on up, to much, much more:
www.amazon.com/Performance-Fuel-Injectio...rsion*=1&*entries*=0
- Skullcrusher
Bikes: 82 kz750 CSR, 03 Suzuki gsf1200s (stage 2), 73 CB 750 bored to 849, big cam, ports head, big valves, lots of other goodies....
