76 kz900 29mm smoothbore issues... video included
  • Lmdgr34
  • Lmdgr34's Avatar Topic Author
17 Mar 2016 10:51 - 17 Mar 2016 11:03
#715841
I have included a video to help describe the problem I'm having. I'm currently running a 120 main and 17.5 idle. If it give it any amount of gas too fast it just dies. It was somewhat better when I had a 25 idle jet. Do I keep going up on the idle jets? I had the carbs syncd and taken care of professionally a year and a half ago, but now that I've gotten the voltage problem taken care of this is now what it is doing. Thanks
1976 KZ900
29mm smoothbores, pod filters, 4-1 pipe....and a whole lot of daydreaming
Last edit: 17 Mar 2016 11:03 by Lmdgr34.
  • strum
  • strum's Avatar
Re: 76 kz900 29mm smoothbore issues... video included
17 Mar 2016 11:48
#715850
where are your air screws set at? try turning them in or out .
example if they are all set at a turn and a half out then go in a half turn to see if it changes.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
  • Lmdgr34
17 Mar 2016 12:08
#715854
if I remember correctly they are 3/4 turned out. I will double check that when I get home, thank you!
1976 KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Mar 2016 15:58
#715885
Mikuni says to start at 3/4 turn then adjust for best idle 1/4 turn at a time waiting 10 seconds each time to let the carb catch up. Keep the idle around 900/1200. If it won't do that, sync the carbs then try again. When I'm done I'll raise the RPM's to around 2500 and listen for a miss. I can usually dial it out this way unless the pilot's are too big.
  • Lmdgr34
17 Mar 2016 16:03
#715886
Steve,
I will have to give that a go tomorrow. I can get it to idle all day long. I just can't give it throttle too quickly or it dies.
Thanks,
Walt
1976 KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Mar 2016 18:10
#715906
What clip position are your needles at? If you change them you'll HAVE to sync the carbs again.
  • Lmdgr34
17 Mar 2016 18:12
#715907
they are in number 3
1976 KZ900
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Mar 2016 18:16
#715911
Good, they are for fine tuning, elevation, etc.
  • baldy110
  • baldy110's Avatar
17 Mar 2016 19:00
#715927
That jetting should work, check your timing advance unit.
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Mar 2016 19:05
#715928
+1
  • spdygon
  • spdygon's Avatar
17 Mar 2016 20:00 - 17 Mar 2016 20:00
#715940
I'm running 29mm on my kz900 as well.
4-1 exhaust and a air box
115 mains
15 pilots
1/2 turn out
Idle at around 1500rpm
Never been able to get them at 900-1200.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 17 Mar 2016 20:00 by spdygon.
  • Lmdgr34
17 Mar 2016 20:02
#715943
I have a 4 -1 and pods
120 main
25 pilots(now)
3/4 turn out
it'll idle at 1k all day long but stalls if accelerates too hard. I'm going to try the advancer tomorrow.
1976 KZ900
