Reference for float height adjustment? 76 KZ900
  • NobleHops
  • NobleHops's Avatar Topic Author
  • Vendor
  • Vendor
  • A happy present from the earth!
15 Mar 2016 18:05
#715585
Hello lads,
Seeking but not finding some reference for the float heights for 26mm Mikunis, dual inlet, no accelerator pump. I believe these are appropriate for a 76 KZ900 among others.
Does anybody know it?
TIA for the assistance,
N.
Nils Menten * RestoCycle LLC * Tucson, Arizona * USA
Proud sponsor of KZRider: kzrider.com/forum/14-vendor-forum/604812...on-shocks-usa#751083
Vapor blasting with free shipping! www.restocycle.com
Discounted Ikon Shocks! www.ikonshocksusa.com
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Reference for float height adjustment? 76 KZ900
15 Mar 2016 18:53
#715595
Hey Nils, glad to hear from ya. Book says 22mm/4mm clear tube test.
  • NobleHops
  • Vendor
  • Vendor
16 Mar 2016 09:14
#715685
Thank you as always Steve!
  • spdygon
  • spdygon's Avatar
16 Mar 2016 20:02 - 16 Mar 2016 20:06
#715785
Do the clear tube test...I have found that not all float neddles are the same. One may take more gas to shut off then others.
If a spring is softer it will take more gas to close it and the level will end up on the high side.
If the spring is harder it will take less gas to close it and the level will end up on the low side
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 16 Mar 2016 20:06 by spdygon.
